New Front Loader
rubaducky
Member
May 20, 2017
14
Texas
Our older Kenmore Elite dryer keeps blowing the thermal fuse. I have taken apart and reset fuse (slam into floor) 10 times in the past two months. Done with it. Will try and make it to Labor Day (for sales) and then pulling the trigger on something new. Maybe something like...
SQ FL w/matching dryer (something like AFNE9BSP113TW01)
LG FL w/matching dryer (something like the WM4370HWA)
Heater vs no heater, built to last forever vs 8 yr disposable, new school vs old school, etc, etc. Need help deciding. My wife already said she didn't care...just "pick the best". As if it's that easy! I do have a tendency to overthink things, so any advice to steer me in right direction is much appreciated.
I'm sure the Sq chorus will start soon, but I'd be hard pressed to justify buying a SQ.  I've been quite happy with my Duets, and if I was buying today it'd be LG.  I think it has the best bang for the buck.
Wash Performance Wise
I'll let you decide!
I'm surprised how long the SQ took when all along I thought one of the things SQ was boosted for was quick cycles.
SQ Front Load (Normal Cycle):
LG Front Load (Normal Cycle):
One thing I will state is make sure, if you choose to go the LG route, you pick a model with TurboWash.
On another note
Do you know what might be possibly making the thermal fuse go out? I have bypassed these before and never had another issue. You might consider that unless you just want to buy new ones. As far as what to get, I personally have a set of Kenmore Elite's made by LG. The front load washer holds a tremendous load and dryer also. The run time is much longer for the washer, but the results are far better than I have ever experienced before. It has the "steam treat" options for both. I have heard different members here rave on and on about speed queen lasting 30 years, but have seen no evidence of that or any indication that they are far superior to anything else out there. In fact there have been members here who have had significant problems with both the front load and top load speed queen washers. They also have a somewhat smaller capacity too. So I think it is really just the luck of the draw mostly. I would at least look at what consumer reports says about reliability and try to go with a brand that is in the upper region of the ratings. I feel lucky so far with the machines I have and have been very pleased with them. They are over 4 years old now with no issues and are used several times a week. Good luck with your decision. [this post was last edited: 7/28/2017-05:21]
People who have LG . . .
. . . seem to be very pleased with them.
At the Beltsville convention this past August, I came home with a SQ FL. I love it!!! The capacity is great. I don't hear it unless I'm standing there watching it. Years ago I had a Duet set. When the washer went into the final spin, it could be heard next door. This SQ does the fast spin and, if I am in another room, I don't hear a peep out of it. It cleans beautifully. I am very pleased with my purchase.
The regular wash cycle takes 50 minutes which includes wash and 2 rinses. The controls are easy to use and one can get 3 or 4 rinses out of a cycle if needed.
Good luck with your choice.
Jerry Gay
Another winner you might consider: The Maytag Maxima series. I had the 8100 pair and absolutely loved them. Excellent washing performance, internal heater, steam feature for stain removal, sanitize cycle for boosted wash temps when washing heavily stained kitchen whites. 4.5 cu. ft. capacity in a 27" wide cabinet. Model 5500 (also with internal water heater, steam and sanitize features) can be found for around $800 and receives a rating of Excellent by Consumer Reports. Mine were on pedestals. Loading and unloading was incredibly easy. Really liked the styling, as well; especially in the gray color. (See photo)
I sold the pair with my house (too deep for current installation in apartment) and spent some time looking into SQ.
If you're looking for longterm durability and ease of service, SQ is your machine. While it lacks an internal heater, it has great options like soak, prewash and up to 4 extra rinses. The washer would sit about 6 inches from my water heater, so I wasn't worried about unintended cold fills.
Ultimately, I went with a SQ top-loader in my situation, but may replace it with a SQ front-loader at some point in the future. I prefer a FL format, but cost and a couple of other factors came into play.
I used to steer friends toward LG (all of whom are happy with them) but I think the Maytag Maxima series is the gold standard in performance and features. If you're looking for something that will last 25 years and is easily serviced, SQ is hard to beat.
Good luck with your purchase, but definitely check out the Maytag Maxima series.
recommend a heater
I would recommend a machine that will heat the water, unless you only wash in luke-warm or cold water. Front loaders don't use enough water to clear the line of cold water before hot water enters the drum, resulting in warm water when you select "hot."
On my old front loader (Frigidaire) without a heater, I'd fill the machine on the "hot" setting, then pause and drain the tub. This would purge the water line of cold water. I'd still only get water as hot as the water heater was set. If your water heater is not next to the washing machine, you may have to do this routine more than once to get a hot water wash. PITA
I like the option of the machine heating the water to deep clean whites and sanitize when needed. Would you want a dishwasher that didn't heat the water?
That's just my opinion, but I would not want a machine that didn't heat the water, especially a front loader.
That rant over, I'll share that I now have an LG front loader with turbo wash and LOVE it. I know SQ is said to be well-built, but the lack of a water heater disqualifies it in my book. As far as longevity, you could buy two LG's for about the same price as one SQ, so you'd spend the same amount of money over time.
Good luck either way.
Thanks for all the info and suggestions. For LG fans, which model do you normally recommend....3000 series (WM3770HWA), 4000 series (WM4370HWA), or 5000 (WM5000HWA).
I'll have to do some reading/googling on the Maxima.
And the SQ front loader still definitely in the running, but no heater does gives me pause....as our water heater is on the other side of the house from the washer.
@bruce...how do you bypass the fuse? Any change of fire...as our washer is right next to our 20 month old's room??? Thanks.
Have you checked the dryer's vent line and blower housing? If either is suffering from lint buildup, your thermal fuse could be trying to save you from a dryer vent fire or it could just be bad. If you use dryer sheets, the blower and lint screen could be caked with greasy lint to the point where the lint screen is almost as waterproof as a submarine. It sounds like you want a new matching set. Nothing wrong with that, but would definitely recommend a heater in a front loader unless your water heater is set at a minimum of 140F, positioned very close to the washer and you are willing to or have the ability to purge the lines of cold water before you start the machine.
@tomturbo
I love to save money, and have done all I know to do save the dryer. I have taken the dryer almost completely apart, checked and cleaned spotless. Dryer in middle of house, and had a somewhat long venting run to a soffit vent. I had an excellent handy man run a brand new venting run shorter and straight up and out the roof. Still, the thermal fuse continues to randomly blow every week.
I thought of making do with an older used dryer for now. But almost to the point where I do not want to have any repairs on a washer/dryer for some time....and that has led me to consider a new matching set.
fuse
Well, I was making an assumption that you were talking about the fuse that is on the back of the dryer in the area that there are thermostats also. I have bypassed these many times before and had no issue at all. The dryer already has several different thermostats to control the heat. There is an operating thermostat and a high limit thermostat also. The ONLY way you might have a problem is if BOTH of those failed and then the heating element would run as long as the dryer was running. I personally have never seen an electric dryer catch on fire before. I have however seen gas dryers catch on fire from a failed gas valve that did not shut off or from a lot of lint build up around the dryer and vent. I suppose that is possible with an electric, but I have not personally seen it before. To me the thermal fuse seems to be just another of many "safeguards" that are made with the intention of something else to go out and encourage the owner to buy a new dryer. Since dryers NEVER used to have those until the last couple of decades, I question how necessary they are. combo52 would probably be able to give you much more insight to that since he has been doing it most of his life and still is. Oh, I also agree that the Maytag you were discussing would be a good choice too. My water heater is a ways away from my washer too and with the steam treat option it gets good and hot without worrying about the hot water supply. With a child, I would think that would be invaluable to you for getting things nice and clean.
Thermal fuses by definition are not resetable when they blow, they must be replaced.  The part of question may be a thermostat, not a fuse, if it works again (temporarily) after whacking it on the floor, as you say.  Have you considered replacing the offending part instead of whacking it?
Well, now I'm not sure :( On the Kenmore Elite, it is the third one back (see pic). Also, I did buy a new one after breaking off a prong during a "reset". It is the silver one on the eBay link.
Roof vents usually have a mesh or hardware cloth type grid to prevent animals from entering and they clog regularly. Friends in FL had them and the dryers would begin to take FOREVER and they knew that was a sign to clean the roof vent grid.  Once one of these things have tripped a time or two, the overheating weakens them and they trip more easily.
Rubaducky, one of those is a non-resetable thermal fuse, the other is a high-limit thermostat.  The thermostat trips if airflow through the element is obstructed, resets when it cools.  The fuse functions as a failsafe for the thermostat and blows if the thermostat fails, or if the element shorts to ground and doesn't stop heating.  The proper replacement "kit" includes both on the premise that the thermostat may be bad if the fuse blows.  The dryer usually will still run if this fuse blows but it won't heat.
Air temperature in the drum is controlled by a thermostat on the blower housing, and another thermal fuse probably is there.  The dryer usually goes dead if this other fuse blows.
LG model
I have the LG 3570. I chose it for the turbo wash and steam features. The turbo wash recirculates the water during wash and deep rinses via two spray jets. It also features a spin spray rinse which is rare in a front loader. The steam feature heats the wash water to about 150 degrees to sanitize and deep clean.
@dadoes -- Just so I understand, which one is the thermal fuse? I am referencing the fuse at the top of the picture (or the left silver one of the ebay link).
The item at top of pic (third from bottom) is the one that keeps tripping, and dryer stops heating. I "reset it" by throwing on floor....continuity returns, confirmed by multimeter...and dryer is good to go until it trips again.
While drying, I have check air temps directly out the back of dryer (with a Thermapen)...and the temps are spot on in normal range. The vents are new and clean.
So are you saying I should replace the thermostat...as it could be causing the thermal fuse to trip? Or maybe the appliance has something sagging somewhere...and is shorting out?? Appreciate any advice...as I have worked on a solution for this for quite some time.
