58limited
I just got this off of ebay and I haven't even cleaned it yet. The power cord looks new. It is an old "crock pot" advertised as being from the 1930s. It was made by A.J. Lindemann & Hoverson Co. There is no model or serial number, the tag on the bottom just lists the manufacturer and the volts/wattage.
The crock pot is metal and seems to be well insulated. It stays fairly cool on the outside. The lid is about an inch thick and insulated. It has an an aluminum insert and a set of triple pots to fit inside. This unit reminds me of the thermowell on a Chambers stove. It has no on/off switch, you simply reverse the plug where it connects to the side of the crock pot to change from low to high heat.
Does anyone have a manual for this?
[this post was last edited: 10/24/2011-23:03]
