New speed queen awn432 fill adjustment details?
Interesting. Before I adjusted it, mine was just below the top holes on the agitator, which was about the 4th row of holes down in the drum. That seemed really low to me. The TL Amana it replaced was at the very top of the drum, right below the plastic collar (set like that from the factory).
I don't want to do anything to damage the machine.
Water level
Assuming this machine is made like my 3 year earlier Speed Queen the water level can safely go up to the point where the metal tub ends and the plastic begins. Some would call that extreme, but in so far I have not had a single problem with that. The way I see it its up to you, but I do agree filling up to the 4th row of holes is kind of low.
When all is open take pics, I'm curious if your machine has any electronics (it sounds like the Eco cycle has an ATS fill)
Will do. I don't remember seeing any, but I was paying more attention to the fill switch. It did have a ziplock bag with what I assume to be a wiring diagram. I can get pics of that too.
Thanks! :)
Wiring diagram is in the Zip lock bag. A quick tip, before closing everything fill the tub up with water just to verify its not to much or to little. Mine took two tries to get it where I wanted.
If curious mine looked like this:
Water level Adjust on SQ AWN432SP 113TW04
Hello everyone,
Just got my Speed Queen washing machine Mod. AWN432SP113TW04 (Full model no. off the inside lid of the washer). I was wondering if this was the latest mod. no. for the AWN432 ?? and what the numbers mean after the basic AWN432 ??
Like to get a better idea how many turns I need to do on the adjustment screw to get the water level up to the first roll of holes. Mine also stops at the bottom of the second roll of holes.
Also, will this adjustment cause any problems with my warranty in the event that I need to use it ??
Thank you for your input.
John Z
Approach with caution
The model that you have purchased likely has the Normal/Eco cycle. This purposely fills lower than the electronic models as it adds additional water after agitation begins. Not sure how much, so adjustment should be made very carefully or you may end up with an overfill condition.
Malcolm
