sudsmaster
I've had a Neptune 7500 set for the past eight years.
I don't leave the washer door ajar when it's not in use.
I don't leave the detergent dispenser lid open when it's not in use.
The washer has NEVER had an odor issue.
I do run only warm or hot washes - rarely do I run a cold wash.
I do use mostly powdered detergent boosted with STPP.
The set is also inside the house, where the temperature and humidity are relatively controlled (as opposed to a basement, garage, or other unheated space).
The 7500 washer also has a sequence in the last rinse where it tumbles more aggressively, to help flush any dirt/suds/debris out of the outer drum.
So, no, Louis, not all Americans have mold/odor issues with their front loaders - even with the much criticized Maytag Neptune front loader.
PS-Citric acid is a very useful chemical. It's also used in metalworking for restoring the protective oxide layer on stainless steel after it's been machined, in a process called passivation. I sometimes use a cut lime or lemon to clean stainless steel cutlery.
