ian_p61
A while ago, I got lucky and scored a 2018/9 Asko 10kg washing machine and heat pump dryer. The owner was getting rid of them because she didn’t like them and they had a couple of problems.
Since getting them home, I figured out the “problems” with each unit.
Dryer : it had blocked filters, some bent fins and a blocked out let pump. It seems to work quite well now. First heat pump I have tried.
Washer: Appeared to work really well, but took forever to pump out and cycle times seemed really long. Stating 1:30 hours, but taking 2 +. The original owner said it needed a new outlet hose- checked it and it was fine. Further digging found a button blocking the pump ( the section the connected to the hose). It now pumps out great, however still take a long time. Last cycle it ran - it gave an E1 error- Thermistor error??? - but at a loss. Assuming it is the element ??
