With this one, you can take a screwdriver to the water level switch and have it fill as full as the 3 belt machines. I set mine to the minimum level for washing, then turn it to maximum for rinsing which, after my modifications, fills the tub way over the light lens, almost to the bottom of the door. The higher water level combined with a spin between each rinse yields pretty good rinsing. Even though there are European design elements to this machine, the outer tub still retains the shallow sump, covered by a baffle, connected almost directly to a very powerful pump. The three belt machines powered the pump from the main motor. The pump had to be able to pump out water during the spin because there was no way the machine could stop spinning and still pump out the water. This one has an independently powered, powerful drain pump and that powerful pump combined with the direct feed from the sump means none of that silly drain water surging between the inner and outer tub causing the machine to stop to pump out the water like some European machines. This one starts to spin hell bent for leather and keeps spinning regardless of balance or amount of water spun out of the load. The recessed sump with the baffle traps the water as it is spun out so that it does not surge between the two tubs. It is proven technology that Westinghouse used since the late 50s. It is not as sophisticated as many of the front loaders imported from outside the US, but it is a very rugged machine. It's a shame so few were made and sold. If you have one, it it something to hang onto. Westinghouse kept front loaders available in this country during a time when the nation seemed obsessed with huge top loaders. The reason Westinghouse kept producing them was the apartment and condo construction industry and the replacement market demand. There was nothing else that washed and dried a full size load that would fit where these machines had been installed. Unfortunately, the relatively small market meant that no money had been put into updating the design and technology that had not changed for over 3 decades so it is good that Electrolux wound up buying White Consolidated Industries. While this machine was clearly a stop-gap improvement on the original design, I would rather have this one than the thing that followed it. That machine had to stop to drain the water spun out at the start of spin, could not handle suds when it spun and actually shut off the pump before the spin ended when it went into the rinses, probably because of the crappy timers.
