New Washer Choice
"I personally would skip both TL options. Most who used a good FL properly would never go back"
Count me in! Our current Whirlpool Duet washer mismatched with a Kenmore (Samsung DV419AEW Equivalent) dryer replaced our old set which was a Maytag Dryer and an Inglis direct drive washer (top load). The washer that we own now, cleans EVERYTHING VERY WELL, towels come out whiter without using bleach, something our older top loader still couldn't do even when bleach was used. If your willing to spend a little more, you could get a great Maytag/Whirlpool FL set, better than the LG. Our Whirlpool Duet is a little over 2 years old now and there are NO ISSUES at all.
Speed Wash
If I get the LG I would like to try Speed Wash Cycle. The salesman at Best Buy said that he has an LG and always uses Speed Wash. Of course if I had mud on my clothes from gardening I would use a Normal Cycle. It does annoy me that the cycle times are so long. Part of it is the extra rinses required by the front load design. Part is the sensing to determine water quantity and balancing for the spins.
My mom had the Bendix front loader from 1944 and we used it through the 1960's because my dad kept replacing the bearing. A lot of clothes for a family of 6 went through that machine. Picture is from Post# 549607. Notice the small door below the tub? You could unsnap the retainer and remove the filter to clean out lint and perhaps coins. LG has this feature in the front load machines, I think Samsung has it also.
Excellent Video
I enjoyed the video and saw that you made other videos of the cycles on this washer, on YouTube. So, no spin between wash and rinse? Seems like this would get more detergent out of the clothes. I could try the other cycles if I get this washer. The spin, while you say isn't that high, is pretty fast and I am sure gets a lot of water out of the clothes. I think the direct drive motor is a good feature.
I did see an LG FL set at Manuel Joseph that was $599 each unit. It is not on the internet, only at the store. That may be worth looking into, possibly an older model.
Needless to say, the glass door on most FL washers is a plus for the entertainment value.
Martin, that's why I won't use the quick wash on my Duet.  How, I will say the LG with TurboWash selected will give a spin/spray rinse after the deep rinse.  But if I was using this wash3er, I'd still select an optional rinse.  I also cannot see anything getting clean in 3 minutes unless it just needs to be refreshed.  I did notice in the owners manual this speed cycle does allow steam as an option.
(Disclaimer: Not my videos but I do agree, I love watching the action especially seeing how the spins fair out) One thing that i do love about the LG's is how they have a re-circulation pump...and the spray rinses in the spin, something I wish my Whirlpool Duet other manufactures added to machines, it seems like a long over due feature so good on LG for that feature and really could cut down time.
Just a thought:
The SQ TL are very well made machines and will likely outlast the other options you are looking at but are old school.  That being said I would still choose them but with the electronic controller so you get a FULL 5 YEAR warranty.  Without buying a service contract.
If you could swing it the BEST option is the SQ FL.  A true commercial washer adapted to home use.  They are quite expensive but will last for decades.  I do not regret buying mine.
WK78
I have the LG 3670. I'd get the LG with Turbo wash. Do you need steam? What is the capacity of the SQ? I can wash my king comforter in the 3670, and do bigger loads than in my Kenmore 90 series. What used to be 5 loads is now 3. Delay Start is awesome- I wake up to a load of laundry ready to hang on laundry day. Laundry day used to be 4 hours, now it's 3. Love the Water Plus feature.
Whirlykenmore78
I agree with you. Last October my beloved Maytag A606 from the 1960's finally bit the proverbial dust. I loved that washer.
It took weeks of research to locate a new machine that was as close to "old school" as that one. Metal gears and actual belts my husband can change himself led me to the SQ TL. I am so happy with the decision we made. No regrets for a moment (and for me that says alot)
I know many like all the "bells and whistles' of modern appliances, I however do not.
I could be wrong -
Back when I got my Duet in 2005 and reading the forums, they did not recommend you use them on a 2nd floor or wood floor unless it was reinforced. I do NOT think this is the case now with modern FL washers.
I will not argue that the SQ TL washers would be great, but out of those 3 things you mentioned, I'd get the LG. But if you had listed WP or MT FL washers as one of your options, out of all of those, those would be my first choice. But that recent post showing the 3,000 used SQ FL's on craigslist - I'd take those too.
48bencix
All I can really suggest to you is that you carefully go through and do a search on ALL of these different machines you are considering. There are some HORROR stories about several of the same brand of machine that you should be aware of before getting anything. From what I have learned from this site, other information and personal experience is front load machines are the way to go. Top load machines just do not do the same job as they used to and the only brand that does, has "issues" with capacity and durability. Just check out everything before making an educated decision. Good luck with whatever set you get.
For people who want a 'traditional' top loading agitator washer, the SQ is that in construction and function.
I've been doing laundry with a SQ top loading washer for almost 30 years now and I am onto my second SQ washer (purchased in 2007). The first SQ ran for 20 years without a hitch. The SQ top loader does what it is intended for extremely well and ticks all my boxes. My clothes are as clean and in as good a state as clothes owned by people, who wash theirs in other premium brand washers; top or front loaders.
The mechanical timer failed two years ago and I got a replacement from the internet for half the cost I would have had to pay if I'd purchased it from SQ or via a repair person. It was an easy repair and I also took the opportunity to increase the water level at the time. When the timer failed (to advance), I was still able to use my washer. This, I believe is not possible with modern electronic controls.
Should there be any other issues in the future I will consider repair before replacement. That is how satisfied I am with this product.
Unfortunately that is not the experience some people have had with sq. It seems that people either really rave about how wonderful they are or absolutely despise them after having all kinds of problems with the machines and service for them.
How much capacity do you need? Speed Queen does not offer a lot. The Maytag offers more, and the LG you mentioned offers the most. Have you had a machine with an on-board heater before? Does Speed Queen dumb down their water temps like some (most or all?)modern machine manufacturers nowadays?
This is why I love AW
Thanks for all of the thoughtful ideas and responses. I do not need a large capacity machine. There are just two of us here me and my partner. I do not have a comforter, using blankets for now. I usually do two loads per week and not crammed in. So a TL from SQ would do nicely. about 10 years ago I would recommend Duet washers to friends. Now I think LG has better quality control. I also like the clean out door on the front of their machines. The Whirlpool family has a solid front panel that you would have to remove to clean out the pump, if necessary. I am in the camp of believing in the quality of the SQ and in talking to the dealer, he says they have very few problems with them and sell them more than any other machine they carry.
I am still thinking about the options and considering your ideas. Although I would like to keep the cost down, the SQ price of $860, relative to inflation, is about what I paid years ago for the MT LAT2500.
Has anyone tried those $299 Amana washers and dryers? Those darn things will probably last as long as anything else, except the SQ.
OK, sounds like you are pretty strong for going with the SQ. What about going with used machines, from a dealer and with a warranty, to keep the price down? Or did someone already mention that?
