mysteryclock
After 5 1/2 years of pretty reliable service, our ca. 2018 GE FL set has finally reached the end of its out-of-warranty road. The washer in particular is making the very loud creaking / groaning / howling "bearing failure" sound whenever it tumbles and spins, occasionally just gives up on intermediate spins entirely (doesn't even start, losing its mind), and it has also now started to leak as well.
Since we moved into this house in 2001, we've had bad luck chasing technology in washers:
<ul>
<li><span style="font-size: 12pt;">The Neptune, with all the issues you can imagine, which died within 72 hours of its dryer dying, and on <span style="text-decoration: underline;">the very day</span> we started potty training our fist kid (who's now 21, so it's been a while.) That was replaced with...</span></li>
<li><span style="font-size: medium;">The enormous Bosch </span>Nexxt 500 series, which had to repaired several times (control boards, plumbing, etc.) and also failed right out warranty, replaced with...</li>
<li>The Cabrio, which never, ever cleaned as well as advertised, beat up the clothes, had a not-great companion dryer, and which had to be completely disassembled to replace the motor (died due to a leak), only to have the replacement die shortly after the remaining extended warranty ended, less than a year later.</li>
</ul>
Compared to all that the GE was... fine I guess, but I feel like I really need to get back to the future here, and go with something that doesn't have an app, won't judge me with its built-in and hugely unnecessary A.I. technology, and most importantly is reliable while still being easy to repair, with good parts availability.
Enter the Maytag commercial set, MVWP586GW & MEDP586KW. These should be the 5y / 10y warranty models, so Maytag certainly seems to be willing to back up their product from the factory for a good long time.
I promise I will post pictures once they are delivered but since I haven't had a proper agitator TL in 23 years, I have a couple of quick questions for the group:
<ol>
<li><span style="font-size: medium;">Easiest question: Powdered detergent (Tide Commercial) - bottom of the tub before clothes, on top of the clothes, or doesn't really matter if I'm starting it right </span>away<span style="font-size: medium;">? I'm switching from pods so I'm not sure what the current thinking is here?</span></li>
<li><span style="font-size: 12pt;"> Should I run any kind of cleaning cycle when it is first installed (bleach, </span>Afresh, etc.)? The manual is silent on this.</li>
<li>Speaking of cleaning, the manual does recommend bleach cleaning once a month on Power Wash, but does not specify the water level. Deep fill here?</li>
<li><span style="font-size: 12pt;">Still on cleaning, the manual also says this, and I have the Tech Sheet, but I'm not sure if I'm supposed to add anything?</span></li>
<ul>
<li><span style="font-size: 12pt;">NOTE: The Clean Washer cycle should be used one or two </span><span style="font-size: 12pt;">times a year. Check the Tech Sheet for access to the Clean Washer cycle in the Diagnostic Test mode.</span></li>
</ul>
</ol>
<span style="font-size: 12pt;">In the lead-up to delivery my youngest son and I are going to wrestle the washer out of the tiny laundry room, move the dryer and clean the vent. Fires are bad, clean vents are your friend after all!</span>
<span style="font-size: 12pt;">Wish me luck!</span>
<ul>
</ul>
<ol>
<ul>
</ul>
</ol>
