The refurbed 1999 Kenmore 90 she has been using for six years threw a leak several weeks ago. I found that the problem apparently is a combination of failing neutral drain and two broken tabs on the tub for latching the tub ring. The leak occurred on a high fill. Doesn't happen on low, the swirling water doesn't kick up high enough.
So I pulled out the 2005 F&P GWL11 to refurb that friend Tony gave to me five years ago when it developed a drain issue. The tub & basket were surprisingly clean (although not pristine by any measure) but the exterior was kinda wrecked with dirt and dog hair in every crevice from his garage and lots of scuffs and scratches. Much nicer after thorough clean-up and a paint job. I thought I found the drain problem to be the drain hose kinked essentially flat where it exits the cabinet. However, upon reassembly and a test-run I found that the motor control board is bad, keeping the diverter energized continuously so it won't drain (unless the diverter is disconnected). Bearings, pump, etc. are all in good shape so I ordered a board.
I also had an idea that I can convert it to a more advanced IWL by changing the console and display board. GWL11, IWL12, and IWL15 are all Phase 6 models that use the same motor board. The display board is what gives the machine its "personality." I found a couple pre-owned IWL12 consoles on that popular shopping site.
No pics of the before and refurb process but will get a few of it before and after the console change.
Will probably fix the Kenmore and sell it (swapping the outer tub from Mom's 1994 KA toploader which is just about done parting-out now and I have a neutral drain repair kit).
