New WP FL lineup
my second question with these higher spin speeds offered on any given machine....
is time frame....how long once it reaches top speed does it stay there for?
most final spins are 6 to 10 minutes, give or take....
I have seen ones climb to top speed and stay there for the entire spin time frame....and others hover around 700rmp or so, zip up to high speed for the last minute or two, and that's it...
you will boggle a salesman mind by asking that question....
Hey Yogi,
On my 1800rpm Miele, it seems to run at 1200rpm for 5 minutes and then ramps up to max speed for the last 2-3 minutes. The Miele’s have this as the default behavior on the 1400, 1600 and 1800 rpm machines that I’ve used.
Cheers
Nathan
Duets
I’m just a bit disappointed in the new machine spinning only at 1200 rpm. I can tell quite a difference in loads spun at 1400 versus 1200 rpm. My Duet vibrates all over at around 900-1000 rpm but smoothes right out once it ramps up to 1200. It is true however that this new machine will extract close to the old machines 1400 rpm spin of the tub is wider in diameter as we suspect. It appears that the colors cycle would be my to go to. However, I do wish that Whirlpool would incorporate the soak option into the wash cycle instead of draining after the soak is completed and draining all the detergent away. A prewar option would be much preferred anyways.
My 2005
duet only spins at max 1000 RPM.......so for me 1200 would be an upgrade and I could still live with it.
I'm a bit confused.....are the new Duets going to have an onboard heater? I skimmed through the cycles on one of those manuals and saw a santize with Oxi cycle which usually = no heater.
Let's go to the video tape
Older AEG Lavamat without recirculation:
Newer (88840) with recirculation:
Notice how much faster initially wash load is saturated using the recirculation than without. Also helps (IMHO)mix chemicals with water and get them distributed quickly as well.
For the rinses you can see as well the "showering" from recirculation achieves good action despite machine using less water than preceding models.
I think Louis is spot on. My old Miele also tumbles continuously while filling, saturating a huge load of terry cotton in less than 3 minutes.
Using paddles that act as ladles are petty much standard since late 1980s and it helps a lot in quick saturation when programming is right.
Furthermore there is practically no chance of contamination with foul water.
Miele's tumbling during fill
Must have come along after my W1070 because it decidedly does no such thing. Will pause and top off when senses water level has dropped however. Otherwise machine has a static fill and only begins tumbling once water level is satisfied.
On the final "starch" rinse if the half-load button is depressed filling stops at about five gallons. However until timer advances the washer just sits there doing nothing. Isn't a long period, about less than one half minute IIRC.
