pumpkina
Hi, All!
I just found this forum today and signed up.
Four days ago, I bought a Speed Queen. Delivery should be by the end of next week.
It's a top-loader with mechanical dials. Here's the model number:
AWN432SP113TW04
and a link to specs:
https://www.speedqueen.com/products/...build-your-own
I'm willing to do preventive maintenance (eg tub cleaning), but I don't want the drama of I'm having with current washer.
I run about one load per week with some clothes very dirty due to working on my car and the house.
I live in an area prone to rust (eg hand tools rust quickly), but it's not cost-effective to run a dehumidifier. My current washer and dryer has some surface rust, probably due to dings/scratches (although my Samsung had a circular rust spot on top, so I must have set something obnoxious on there).
I'm the type of person who wants my appliances to last a long time, and I've been through a Maytag Neptune and a 4 year-old leaking Samsung front loader (not covered by the recall/class action lawsuit).
What are common problems with this model?
I read about the leaking tub seal replacement repair and it's pretty intimidating! How common is that? Is there anything I can do to reduce the chance of having to do that repair?
The washer needs two special tools:
725P3 which is a kit including the hex nut wrench, spring hook, and two agitator hooks
294P4 or TJ294P4 (agitator drive bell puller) for Drive Bell 39508P
They're a bit pricey. Any inexpensive places to find them?
The drive bell looks like a generic 4" gear puller would work. Any thoughts on that?
How hard is it to get the agitator hex nut off?
Is there a problem with using anti-seize on the hex nut threads?
Should I loosen the hex nut right after the warranty expires, then put anti-seize on the threads? Ditto with anti-seize on any other components?
Are there any other special tools I should have?
Any suggestions about rust prevention?
After the 3 year warranty expires, what sort of additional preventive maintenance should I do?
Are there parts that I should have on hand and/or replace on a preventive basis, like having a spare tire for the car?
Replacement motors are pricey. Have you rebuilt them or had a motor shop do that? If so, where do you find replacement bearings and carbon brushes?
Is the motor brush kit/assembly part number 927P3P used in this motor?
Ditto with transmissions. There is a pricey ($70) transmission rebuild kit, p/n RB150004, S/N9501 that contains two (silicone?) tubes 24 oz of transmission fluid, CW Trans F-94, 27243P for $22 and a rectangular block. I presume that synthetic car automatic transmission fluid and automotive gasket sealer would be more than adequate?
I suppose Youtube has videos on repairing Speed Queen dryers. Any ones in particular that I should study?
I bought the TL on my Visa, so I get an extra year extended warranty. They told me that if I have a problem during the extended warranty period, I can get any professional appliance repair person (eg independent shop), to provide a written diagnosis. Submit the diagnosis, warranty card, and receipt to them. Actually, I can submit the latter two on-line to make things easier. They'll reimburse me cash and I can either repair it myself, have a tech repair it, or buy a new unit.
I've never deal with a credit card extended warranty. Any suggestions for dealing with extended warranty service?
Thanks!
AWN432SP113TW04
Thanks!
