mickeyd
Wringing 101
The wash was wrung from the washer into the first rinse tub and sloshed. Then the wringer was moved to the position between the rinse tubs or sinks, and the load was wrung into the second tub where it was sloshed. Next, the wringer was moved to the third position, now making a total right angle to the washer, and the load was wrung into the waiting basket. This was the standard method.
No extra wringers were needed. It might be hard to picture how versatile a wringer is, and I'll try to show the method soon. Again this was very standard, universal practice in most old homes with two set tubs in the basement. All wringers have this versatility, except very ancient ones.
Wringer flexibility is probably not widely known unless you've actually used one, because conventional washers are usually pictured with the wringer in only one position, straight across the back of the wash tub.
The hand-cranked wringer one sees screwed into old laundry sinks are vestiges of the days when laundry was done "by hand," that is, on a washboard. Once electric conventional washers and their attached movable wringers became common, the hand cranked models were largely abandoned.
[this post was last edited: 5/15/2012-00:14]
