no warm water on my maytag A700
cradersd
Member
May 29, 2015
6
san diego
I love this washer and i have done my own repairs on it for the last 30 yrs. this one has me stumped. cold water and hot water work fine, inlet valve solenoids are good (tested) and the temp switch is new. I am not a technician, just love this washer. what should i try next? does anyone have a wiring diagram for it? the only one i could find on line shows only 2 solenoids on the inlet valve and my machine has 3.
When you choose warm for wash do you hear any buzzing with no water flow?
If not, more than likey the warm temp solenoid has gone bad on the water valve. You can test the timer / switch operation by switching the warm wire on the hot side. If during wash and rinse you get hot when you choose warm you know your switch and timer are okay.
Water valve solenoids are pretty common. Most varieties from two temp valves of the same age will swap with little issue.
If you do hear buzzing the valve may not be opening all the way. It can be rebuilt with rebuild kits, but it may be easier for you to find an NOS 3 way valve. You may be able to switch in a hot/cold valve, however you would lose your warm temp.
Ben
thanks for your reply. yes, there is a buzzing noise. and the timer is a replacement and so is the switch. the solenoids (all three) test fine. Any idea where i might fine the nos 3 way valve? still could use a wiring diagram so i can be sure i've got this put back together correctly.
thanks again to you for a reply to a newbie!
cathy
Here's a wiring diagram.
So the valve does buzz when you choose warm but no water comes out - not even a trickle? A valve rebuild would be helpful, however, I'd put in a new valve at this point.
I've heard through the grapevine that Larry at Modern Parts in Parma, OH may have a valve on hand for you. Tell him your Maytag model and he will know what to look for. Google the business and the city for the phone number.
Ben
Well my part is here and i will let you know if it solves the problem! Thanks for the tip - Larry had the part in stock.
cathy
Cathy, you are welcome. If you need help or advice in the future please don't hesitate to ask.
Maytag used a three valve water valves on TOL machines up until the early 906 washers. The warm valve provides a regulated warm output, via a thermostat built into the valve, providing approx. 100 degree warm water, rather than relying on mixing both cold and warm with two valves and no regulating thermostat.
Ben
Aussie equivalents?
do any Aussies know if an equivalent 3-way valve was used on any Australian machines? I'd love to add a temp controlled warm fill to my machines. I always disconnect the heater on my machines as it draws too much current for our solar power system, but I like to wash in "warm-to hot" water. As the temp of the solar hot water varies from day to day, a temp controlled valve would be great.
I have never heard of these valves before, I'd love to find a 240 volt equivalent.
thanks
Chris
