Now considering Maytag set
jimmyb
Nov 15, 2004
254
Texas Y’all
It looks like the Cabrio and Kitchenaid set are no longer available. I am now considering a Maytag set but am curious if this is too new to be a dependable care, can anyone help? Thank you!
EEEEEEKKKKK! Not even close to being a Dependable Care Newton Built washer. Dont even bother! Tons of issues with this design. From the Celcon plastic gears transmission to the Plastic drive pully. Leaks galore. If you want a headache get this washer....
And stay away from the dreaded Amanatags too. They have the SAV model numbers.
If you want a dependable washer, get a mid 80's Maytag true dependable care washer. There are a ton of them out there. Kind of boring, but will last forever.
Then of course, there is the Fridgidaire 1-18 too.
NOW I'm really wishing I was in your area!!!!
MAH7500 set! This is actually on my wish list!! The touch screens make life so much easier plus all the on board diagnostics are tech friendly! ARRRGGGHHH!!!! I'd SERIOUSLY think about this set!
Good luck. If I post any more, I'll probably be stepping into QSD-DAN's territory... LOL!
RCD
A neighbor had this model and it blew out the bearings within 3 years (or was it less time?) sounded like a freight train when spinning.
I'm guessing water leaks displaced the lubrication.
yes it is!! The last rendition of them. It has varibale water level, 3 speed combos, and 3 temp combos. And 2nd rinse option. A secretary at work, with my assistance, actually bought htis model at a Maytag store. it was in their Performa line and was the only porcelain-tub model in the Performa line at the time. It's pretty much very similar to a 1994 dependable care.
Yep. These are the very very last look of the Dependable Care line. The washer probably starts with LAV3600. We sold plenty of these. Such a shame, such a shame.
