Wiring Schemes I've Already Tried
Here's what I've tried based on some info I found on line:
Placing the spade from the black coil lead onto the "G" (ground) terminal on the network block (as shown in link pic).
Placing the spade from the black coil lead onto the "L1" terminal on the network block (green line cord lead also connected here).
Neither of these positions helped. The black ringer lead was on "L1" to begin with.
The rest of the leads from the ringer coil are attached to the network block as follows (again, see link pic):
Red lead connected to "L2" (red line cord lead also connected here)
Slate lead connected to "K"
Slate/Red lead connected to "A"
The attached link contains a photo of the suggested configuration. This photo shows the same arrangement I currently have on my phone. The arrows numbered 1 & 2 are showing the suggested fix of moving the black ringer lead onto the L1 terminal from the ground terminal. As stated above, my phone was configured that way when I opened it up and still wouldn't ring. You can see the red and slate leads soldered to the coil at the top of the photo, and the other ends attached to L2 and K terminals. The black and red/slate leads are not visible where they attach to the coil but you can see them screwed onto the ground terminal (black, along with yellow line cord lead) and at terminal A (slate/red) which in the photo appears closest to the coil.
I think I read somewhere that depending on your telephone provider, switching out the line cord leads between L1 and L2 terminals may be required to get your phone working properly but I know that switching them out didn't matter where dial tone is concerned on my phone. It works fine either way.
Otherwise, I seem to have exhausted on line resources and find myself being circled back to sites I've already hit.
I may change out the entire ringer coil and see if that's the problem. I hope not. I'd like to keep all of the original 1950 parts on this phone if possible. It's super clean and pristine where the guts are concerned. Even the leather covered feet on this phone are that brand new reddish color and not brown, smashed and way used looking.
I also read that some phones may be configured for party lines, and that could effect the ringing circuitry. Any knowledge that can be shared on this situation would be greatly appreciated.
http://www.porticus.org/bell/images/500ringerrewiring.jpg
