OKAY the Corrected instructions for tweaking your SPEED QUEENS
jetcone
May 2, 2001
7,678
Schenectady-Home of Calrods,Monitor Tops,Toroid Tr
Jeff & Tom pointed out to me I flubbed the original instructions for tweaking your SQ washers! So after going back and trying to read what I posted even I got confused. So here are the corrected easy instructions for upping your water levels and throwing out your warranties!!
There are only TWO adjustments you need concern yourself with. The important thing to remember is that both MUST be equal. If you turn one IN one turn you MUST turn the other one IN one turn.
Turns:
 1 turn in = up 1/4 inch
 2 turns in = up to bottom of glass door
 2 1/2 turns = 3 times the original factory setting =ample water IMHO.
So here is the photo, use the BLACK screw as your reference when viewing your water switch. Note both screws are on opposite sides of the connector bar.
Start your engines ladies and gentlemen!
Can you define what is meant by "in"?
I'm assuming that means clockwise to raise, counter clockwise to lower?
Where is this pressure switch located?
As well, perhaps you could provide a link to the older thread? I can Google it, but perhaps you'd already know. :)
Nevermind.. I found it here...
I hope that the Speed Queens are still adjustable by the time I need a new one because I definitely want to do this, although I'm not sure what you mean by turn "IN" and does this need to be done at the same time and how exact does it have to be?
Lefty loosey, righty tighty; like turning a screw clockwise (to the right) to make it go in and counterclockwise to take it out. Both screws need to be adjusted, but you don't need to screw both at the same time. Just give them the same amount of screwing before you stop so both are screwed in the same amount and neither one is unsatisfied or jealous.
Yes, I agree that that's the perfect water level. Now I REALLY want a SQ.
I know some machines on the market do not allow you to adjust by the way they are designed.
I fill mine much higher on the glass for rinsing, but it is a manual operation. Jon, your video is paired with a really cute video of Loki the cat being fascinated by the human servant's flushing of the toilet. You Tube is so educational.
That's a very good level...plenty of wash action and water. I didn't realize that the water comes from the top front center and onto the load. I have been thinking of maybe getting an SQ front loader for here in Mass. I like the simple controls....
Peter
 you could open/close the door quickly- but all that water will fall out.
Gansky you will be GONE to the MART before I'm through with you!
Mike- the fins on the drum are solid sided not perforated and so I just saw that that creates a  real lifting action to the water and picks it up and sloshes it over the top of the load as it tumbles. With the big window door you can see this, with Gansky's tiny porthole machine this is lost to history!
Interesting video.
In another thread water levels were discussed. Conclusion was that a too high water level in the wash would result in worse cleaning results because laundry has to tumble, not roll over in the wash. Higher water levels are good for rinsing, roll over is good enough for rinsing.
Does this machine have different water levels for washing and rinsing? And does it have a higher water level in the delicate cycle?
