launderess
My AEG-Oko Lavamat has an "Energy Savings" cycle. All the manual states is that cycle gives good washing results with savings in both energy and water at "about" 60C.
Considering how stingy this washer already is with water one notices the Energy Savings cycle uses two gallons less water but runs for 120minutes. However electricity use is reduced to just .89 kWh.
So how does the cycle "save" energy? By washing clothing longer? Not reaching proper temp (60C)?
To it's credit one *thinks* you can also program "sensitive" as part of the ES cycle, this will give a different rinsing pattern and add an additional rinse (Rinse+). Since have long programmed the AEG to use Rinse+ automatically after all cycles were possible, the only difference would be the how in rinsing.
Ta!
Ta!
