Re: "S" Model:
Hey! John, seeing the "S" in front of the Model Numbers, if I'm correct indicates that this is a Suds Return Washer. Does your Lady-K have 2-Drain Hoses on it? If I'm correct, in the 2nd Pix you Posted on the longer Normal/Cottens & Linens Cycle area, right at the beginning of the Cycle it says "Suds" or "Suds Return" am I correct? If I am, then it is a Suds Return Washer.
I'm surprised that no one else noticed this right away, when you Posted the Model Number. It is a 1968 Model Year, I bought the same Matching Washer and Dryer in Coppertone for my Parent's. When I first looked at them, the Dryer had only an all Automatic/Moisture Sensor Drying, with degrees of Dryness from Damp to Dry. When I was ready to order the Set, they had a newer updated Model Dryer on the Floor, that had Automatic and Timed Drying and the 2-1/2 hour Wrinkle Guard feature as well. Neither machine ever really had any problems for quite a while, but later on, the Timer started acting up and had to be replaced and the Belts were replaced a few times as well. After the original Timer in the Washer went out, the replacement Timers weren't quite as good as the original Timer, until after about 4-Timers installed, the last one ended up being almost like the original Timer, quality wise.
Enjoy your Lady-K Washer, treat her great and she will give you plenty of years of great performance and clean Laundry.
Peace and Fun Lady-K Laundry Times, Steve
SactoTeddyBear...
