Out of the archives
Love the 1964
spin tube finale........story about the easy loading from the front. "Makes loading easy even when you're wearing your best party dress".
I always take my long sleeved shirt off to do dishes and clean the kitchen. Maybe I should wear a dress.
The design fallacy of the spin tube was that glasses did not need as much water force as items with heavier soil did, yet they were placed right over the water supply.
Note that in the puce background spec sheet, they show a Corning Ware pan with very dark soil being scraped under running water, yet there is no follow up picture of it in the dishwasher showing where it was placed or how clean it emerged.
Well of course not.  that's because it ended up being completely washed by hand because there was no place in that load depicted in the pictue for it to be placed nor would it have proably come clean in the first place.  To accommodate that piece in the top rack, numerous glass and cups would have been  put back in the sink.  And attempts to place it in the bottom rack on its side along the right side of the rack, facing the center, would have resulted in too many plates being left out too!!!  "Prepare your dishes as if for hand washing".  Looks like that Corningware piece was being washed by hand completely anyway!!  Probably with lots of dish soap in that rag or sponge being used.
GM - Mark of Excellence
I know these weren't stellar performers but you have to admit, they sure looked nice! And if you were wearing your best party dress and wanted to show off your new Dishmobile, might as well have something with lots of chrome........
Now it's difficult to even locate the dishwasher in a modern kitchen.
Hi does anyone have the picture of the first ever front loading dishwasher which I thnink would be American and was it in the late 1930's it hit the US market
Less about performance than capacity
Thank you for all the wonderful scans, Steve--great to see you posting!  I LOVE that Sherwood Green set--what a handsome machine!
Bob and I used to joke that a KDS-15 and a DW-IMH made for a harmonious household; the KitchenAid was the "bottom" dishwasher for pots and pans, and the Frigidaire handled all the cups, dishes, and otherwise flat items.
You may remember when the DW-IMH came home--the first load was a bust, and I was perturbed as much by the performance as by the inability to load a plate larger than 9" in diameter.  (The top rack hit them.)
But with downsized dishware, good detergent, the true detergent dispenser and double-wash (rather than the door-divet and single-wash), and VERY HOT water in copious supply, the spray-tube did a good job.  I even learned how to be adventuresome and get fry-pans and serving ware clean in the lower rack.  The hydraulic physics of the spray-tubes seems counterintuitive--but water went everywhere, and most everything got clean, believe it or not.
That said, I wish they would have kept the top rack of the fifties machines and not opted to put a ridge of fixed tines up the middle in the '64; this made loading deeper pots and such nearly impossible (nor mixing bowls).  In the older machines, the top rack was a nearly flat hump, minus the tines, and the loading for odds-and-ends was more flexible.
The situation for tumblers was grim.  If you use a lot of tumblers and not teacups, you pretty much lost your top rack to them; even though you had a full top rack, tumblers ran up the sides and formed an array that reached the sides of the rack, making fitting much else (beyond Glad-ware that could nestle between the bottom of the glass and the side of the rack) impossible.
These were definitely dish---not ware-- washers.  Water sent to the silverware basket (though generously sized) was not entirely adequate.  But on mine, the self-cleaning pop-up filter worked well and shed most of the food down the drain; I never did anything special to prep the dishes, and everything came out sparkling.  Of course, I didn't put baked-on stuff in, but that was a ludicrous proposal for most dishwashers of the time, anyway.  (At least soak the thing first.)
The machine was very quiet, and reminded me of a soft rainstorm when it ran.  The massive reversing impeller shoved a huge amount of water up to that tube (evidenced by the monstrous feed hose, similar to a radiator hose from a '54 Pontiac), and mine had big slots cut out of it that must have sent ribbons o'fury spiraling around the machine.  The drain phase of the cycle could fill your sink with water, and I'm convinced that fire departments borrowed spray-tubes to fight high-rise fires from the ground.
