Received the w-2F4 on Monday, and tested for leaks. It was leaking at the pump. I gave it a dry run previously, and it started agitating. I advanced the timer to spin, however no spin. With a little counterclockwise help, it began to spin. I took the pulley off of the bottom of the clutch, and removed a spacer form behind the lower cam, put it together and away she went! Apparently the previous owner
Just went out and bought the 70's filterflo, to fix the spin problem. I am amazed at how little time is on this machine, you can just tell. Anyway here are a few picks for those who care...
