Had a chance to pick up a used Bosch dishwasher the other day on a local exchange site. It is model number SHU43C06. This is will be replacing the currently built in machine which was a Point Voyager based KitchenAid. While that particular machine worked ok, it was sometimes fussy and just didn't live up to it's KitchenAId name. I got the Bosch in and have run a load through it so I'll just give some observations I've noticed about it in no particular order...
The build quality is far better than the KitchenAid. The door feels much more substantial and the lock sounds like a bank vault closing when it snaps shut. After cleaning it up it has a nice high gloss shine and in fact almost looks brand new. Definitely has aged better than the KitchenAid did.
The manual indicates that this has Nylon racks. As far as I can tell there aren't any cuts, nicks, or rust spots in the racks. I could not same the same about the KitchenAid.
There is a base pan under the motor than goes all the way to the floor. There are two channels basically that you slip the water hose and the electrical wires through from the back. The manual also indicates that this machine has water sensors in the base.
This model is not an alternating arm machine, it runs both arms all the time. Again the manual indicated that the alternating arm system was called "Flow Control" which distributed water to either the upper, lower, or both spray arms. Flow control was not optioned on this model and listening to it run I never heard any alternating, and every time I opened the door both arms had moved position.
The lower wash arm only has 6 holes in it, plus two downward facing ones. The tines have very close spacing as well in the lower rack but I guess the jets must fan out or they are really well placed. The upper arm has 8 holes, plus 2 downward facing jets. The constant rinse nozzle is not positioned in the middle of the top of the tub, but rather about a quarter of the way back.
It starts with a purge, and does a purge after every drain. I used the Power Scrub Plus cycle and the sequence was Purge, Rinse, Purge, Main Wash, Purge, Rinse, Purge, Final Rinse. According to the manual it should have been 138 minutes long with a 160F wash and rinse. However the machine put 125 minutes on the clock and when I checked the sump temperature in as it was draining for the both the main wash and final rinse the water temperature was only 145F. Also the sanitized light did not illuminate when the cycle was over, which presumably it should have done.
First load just finished and wow everything is exceptional. Absolutely no yibbles, which again the KitchenAid struggled with. The filter also was clean and this was a fairly dirty load.
There isn't a vent on this machine, it says it uses condensation drying. The dry period is only 12 minutes long. Is it just the residual heat from the rinse drying the dishes or is there some extra system working in it?
Anyways, I'll have more observations and pictures as I have time to play with it. I think this is going to be a keeper though! I'm looking forward to really putting it through its paces.
Cameron
Cameron
