wft2800
I'm guessing late 50s/early 60s here? 29" wide, only 25.5" deep - what's all that width doing, then?!
Looks like a bottom-of-the-line machine, single-speed, no controls whatsoever other than the timer. Yet it mentions that the washer will fill with water (at the) temperature selected, but I can't see a temperature selector!
"The gold-trimmed, white opaque plastic timer knob with its red pointer is in the center of the panel" - err, it looks to be offset significantly to the right to me...
Cycle time - washing time selected plus 18 minutes. Is that for the rinse and spin, or does it pause the timer for additional washing?
Seven rinses - I'm guessing wash, drain, spray, spin, spray, deep rinse, spray, spin, spray, second deep rinse, spray, final spin?
"Safe" spin speed of 500rpm - in other words, we can't work out how GM make their Frigidaires spin at 1140rpm without knackering the bearings and transmission, so we're going to imply that such high spin speeds are dangerous...
I presume that "Free-Flow draining" means a spin-drain? Was this perforated-tub machine derived from a solid-tub one, or was a spin-drain just preferred? The marketing is evidently attacking neutral-drain machines, whether front or top-loading.
