POD 1-16-2023
maytag85
May 11, 2017
3,270
Sean A806
I have a identical Maytag A606 set in avocado featured in today’s POD. Acquired it back in March of 2019, while the washer worked, the matching DG606 needed quite a bit of restoration since there was corrosion from years of constant burning pilot light. Ended up converting it to a DG306 and haven’t had any issues with it other than having to replace a cycling thermostat back in 2020. The Maytag A606 set is currently not in service at the moment since the water valve (at least the hot solenoid kept sticking open) and will have to replace that. Currently using the Maytag A806 I picked up from waterwitch last summer and the customized Maytag dryer I am trying to put together, only things that aren’t working on the Maytag A806 set are the lights but will look into that sometime this spring. Technically I own 2 of the sets featured in today’s POD but the Maytag A806 I have is much newer and the A606 in the POD is from about 1973 or so.
