pricey Roto-Rack
It is amazing that it does not have rust stains in the sump/tub. Porcelain in D&M machines was so thin that few, if any,  made it out of the testing at CU without showing rust and it was noted in the ratings.  Other than that, if you boosted the wash temp, the hotter water and longer time would produce clean dishes, but I don't see where they came up with the price unless it is our of sheer ignorance and there is a lot of that.
That was the eexact model we had for weekend getaway house. Bought fall of 1971 or 1972. Ours was harvest gold. Model just under the LK. the bottom rack is in backwards.
a popular dishwasher
Sears sold a LOT of these D&M machines. Not a bad dishwasher, in reality. My family had the Modern Maid version of the D&M machines, which my dad bought in 1968.
It had really good scrubability, as far a pots and pans, baked on foods, etc. But, it did have an annoying tendency to leave little nibblets of food, which had been ground up by the "macerator" blade, on the tops of glasses. After the dishwasher went through the dry cycle you had baked on nibblets.
After two years, though, the motor had to be replaced. Then it worked fine up until 1973 when my dad replaced it with a General Electric Potscrubber. I don't recall why it was replaced, probably had rust-through of the tub.
The used house my sister and brother-in-law bought had a similar Roto-Rack, as the one picture above. Oddly, they did not seem to have the nibblet problem. I guess the centrifugal force, from the rotating rack, flung the nibblets off the top of the glassware before they could accumulate. That upper rack could get some speed on it.
The only negative thing they said was the top rack sometimes got out of balance if you had something really heavy on one side of it. It didn't get out of balance as a washing machine tube does, as the rack is locked to a central axis, but it did wobble a little vertically (sides tip up and down). and could make a thumping noise when out of balance.
They didn't have it long, though, as they soon remodeled the kitchen after moving in. They replaced everything with General Electric appliances. Which I thought was interesting, as my brother-in-law worked for Frigidaire, at the time, and could have gotten his employee discount on appliances.
Sears / D&M
Back in the 70s I went to install a dishwasher in a kitchen that had never had one and bought a Sears version of this. Upon installation, me being the picky person I am, I took the racks out and inspected the sump area of the tub, only to discover that most of the screws had cracks in the porcelain next to them. You could already see rust along the cracks. I took it out and back to Sears, and replaced it with a KA Imperial. End of D&M in my kitchen
My aunt and uncles DW exact from their 1972 built house.
It worked for them until about 1985 when the leaking had just been too much.
They replaced it with a White Westinghouse that the retailer did a crap job installing and it slowly leaked and rotted the floor.
This thing even has the original door seal.
And yes, that lower rack is in backwards.  That door would not have shut all the way with it like that.
I forgot about those cycle progress lights.
The Lady K with self advancing timer would have the same PLUS
an additional strip of lights to indicate each phase as the timer progressed.
Add that to the two lights behind the escutcheon lens, it was like Christmas.
