Primus W-10X^2 update "I need Control!!!"
supremewhirlpol
Mar 25, 2009
2,134
I've done a few things to Primus W-10X^2 over the Thanksgiving break. Something interesting came in today. Can you guess what it is? The video should give you a good hint. And, yes it has to do with Primus W-10X^2 and it's all about CONTROL!
gee, what could that be melvin?
either you got some type of control board or timer for that washer or miss janet paid you a personal visit over the holidays and lost all control when she saw your collection of commercial machines and that bendix you have. i'm assuming the latter.
love the video, brings back memories of the 80's when i lived in minneapolis and prince was hot, jimmy jam and terry louis were hot and janet was beyond hot! used to go down to the gay 90's on hennepin ave. and listen to the "minneapolis sound" including janet while we danced the nite away. then take a bus ride home in 10 below weather! ah, what memories!
why don't you post some pics of that machine of yours! it is one major "no nonsense" washing machine, from what i remember when i saw it. had a great time with you when you came to visit, enjoyed showin you my stuff too.
OK, Before we get to the CONTROL part I need to back up a bit. Several weeks ago I decided to mount the control box to the side of the cabinet. So, to do that, I needed to dismantle the cabinet. The back pane has to come off.
Next, mounting the motor: In order to do that I needed to cut some things. Here are the grinder wheels that I used.
The original motor mount tabs needed to be cut off and grinded down to be flush with the frame. Those tabs are strong and thick.
Next task: Bar cutting and wielding. I had the choice of using Arc or Mig wielding. I chose Mig because I don't know how to use the Arc wielder. Here is a picture of the type of Bar that I used. Two bars were needed at 23".
Now that the motor has been mounted, put the cabinet back together. I left part of the front open because I don't know how big the User Interaction Panel will be. PLC enabled User Interaction Panels are extremely expensive. $250-$2700 range.
Now that I have added the Control Box and the motor, this machine is VERY heavy. This machine is so heavy that I had to have my brother lift on the other side just so that I tilt it on the dolley. The control Box weighs 60LB. and the motor weighs 105LB. I would say that so far this machine probably weighs in the upper 400LB. range. It is surely heavier than the original Primus W-10.
Now CONTROL: Pete, If Janet came to visit me that would be SOOOOO awesome!!! But that didn't happen. Some type of control board? Very close! What came in the mail is!?, drum roll please: A Variable Frequency Drive module!!
Model ATV18U54M2
Input is 230V 3PH True Sine Wave
output is 230V 3PH Modified Sine Wave
It's rated to run a 4HP motor, so it being oversized isn't a bad thing.
This is a picture while testing it. I still have to properly program it, but I needed to test it to make sure that it worked. I found this one on Ebay for only $79.00. That is a steal, considering that other used modules were priced in the $300-$400 range. When power is applied to one of the inputs, the VFD will run the motor. When the motor is running, it makes a very high-pitched pulsing type of noise. I only wish that my cameras were here so that I could take a video of running the motor. This VFD module is one of the more expensive ones in that it is very versatile. I can have the motor do anything that I want. I can set profiles, braking, rampup and down, etc. and etc. Now That's CONTROL!!
Melvin I am so happy for you... I hope everything works out nice washer.
Will you be able to work programs as you like it ? And speed and drum rotations ?
Thanks Darren,
I'm still a little ways from programming cycles. I haven't put anything in the control box yet. There is still lots of electrical work that has to be done. I still need to get cards for the PLC: DC in, DC out, Analog DC out, contactor and thermal overload for the VFD, wire, triac card, a power supply 240V AC to 24V DC 15A. Yes the VFD allows me to make the motor spin as fast as I want and as slow as I want. I can make custom acceleration ramp profiles. I can change the rotation and apply braking. What is nice about this particular VFD is that I can set the motor for either constant torque or variable torque. The motor nameplate RPMs are 3520 at 60HZ. Being that everything else is the same, the VFD can go from 0.5Hz to 320HZ. I can make this motor scream if I wanted to. The PLC and User Interface Panel will allow the user to make custom cycles. I have to wire everything up before I can start programming the PLC. Programming the PLC to interface with a User Interface Panel will be a very tough chore. When the washing machine is finished, I can make it do anything that I want to, it's just a matter of programming the PLC.
melvin
those pics are fantastic! and all the work you've done! it's amazing how you put those huge motors on your machines!
next time i'm up you'll have to show me the finished product.
great pics!
hotpoint 95622
It’s good to see the progress of this machine, keep the updates coming.
I have just managed to complete a working PCB, have about 6 units that are no good, suppose you call it learning the hard way.
Next job is to iron out the bugs in the programmes, mostly to do with the interim spins.
Photo of working PCB.
