passatdoc
G'day, I've been reading AW.org for several years and have noticed Australian readers mention both TL and FL machines.
FYI, FLs were made in the USA from shortly before WW2 until I believe the late 1970s. Westinghouse probably made the lion's share of them, but Bendix, GE, and others also made them. The early FLs couldn't match top loaders for speed or capacity and, prior to the development of high final spin speeds, they had little edge in water extraction.
Until 1997, when Maytag introduced its Neptune FL, one could find imported Miele or other European brands in high end, specialty appliance stores, but not in mainstream appliance stores (e.g. Sears). So it's only been in the past ten years that US consumers have had a choice between TL and reasonably priced (in some cases), mass-marketed FL machines.
ff(i.e. I'd define a Whirlpool for $800-900 as "reasonably priced", whereas a $1600 Miele may be worth the money, but it's not "mass market priced" because the average American cannot afford $1600 for a washer alone. A $650 Frigidaire can do an adequate job, even if it's inferior to a Miele at more than twice the price).
My understanding is that FL sales now exceed TL sales in the USA, though whether either design can compete with a vintage TL is another matter. If one goes house to house for a survey, most likely TL machines still outnumber FL machines, but as those machines age and break, I believe eventually FL machines will outnumber TL machines.
On my last trip to Australia, I was in a number of private homes (since I was visiting friends as well as playing tourist) and I noticed a mix of FL and TL machines in the homes I visited.
So here are my questions:
1. What % of new washers being sold in Australia are TL vs FL?
2. What % of existing machines in Australian homes are TL vs FL?
3. Has the market share of each type been steady, or is there a trend toward FLs?
4. Was there a time when FLs were not mass marketed in Australia? (there was a roughly twenty year period in USA when this happened).
5. Over the past 10 years, Australia has experienced some pretty severe drought conditions. Has water scarcity prompted a move away from TL to FL machines? Are there financial incentives or rebates to encourage FL use? (in Southern California, there is a $125 rebate from the metropolitan water district for the purchase of a FL; a few FLs do not qualify based on "water factor use" but most FL machines sold do qualify for the rebate. There is also a $30 rebate from Southern California Gas Co.).
I would imagine TLs are plentiful in NZ due to the presence of Fisher and Paykal, but obviously NZ does not face the same water scarcity issues that Australia has.
PS: to give you an idea of the scarcity of FL machines in the US at one time: my home was built in 1988, with laundry area in the garage. There are several reasons why homes in Southern California have their laundry area in the garage: 1. The pipes don't freeze here. 2. House stays cooler with dryer out in the garage, particularly in areas (like mine) with mild summers where air conditioning is not needed. 3. The garage slab is typically 15 cm (6 inches) below the house floor, so if there is a water leak, it flows out the garage door but does not cause water damage inside the house. The garage slab actually has a slight slant downward toward the door (maybe one inch over 20 feet) and any water spilled on the slab inevitably heads toward the street and not the house.
Building regulation in my county requires a bollard (concrete filled steel pipe) to be embedded in the garage slab and it's about 75 cm (30 inches) high, to protect the appliances from a runaway car (don't want to sever gas lines and blow up the neighborhood, now do we?). Because virtually no FLs were sold in USA in 1988 (except for high end appliance stores selling a few Miele or Bosch machines), the bollard was placed directly in front of the washer space, effectively blocking the door of any future FL machine. But they weren't thinking along those lines because all mass market choices were TL in those days. I circumvented the problem by buying a washer and dryer that could be stacked using a bracket from the manufacturer, and located them in the dryer space, which is not impeded by the bollard. Even with a pedestal, a washer door would still be blocked (not to mention the inability of opening the pedestal storage drawer....).
