llmaytag
I recently purchased a new Whirlpool washer after I discovered grease below my Maytag Performa LAT2500AAE washer and determined that water was leaking from the tub seal when I would wash a load at the higher water levels. (Note the grease in the attached pics.) This Maytag had the larger white porcelain tub, which isn't quite as large as the polymer and stainless steel tubs and I really loved the very basic design of Maytag washers which really had two phases. Turn the transmission one way, you get agitation, the other, you get spin and drain. Anyway...
Having the tub seal replaced would have been nearly $300 and I probably couldn't have done the job myself. It broke my heart when I discovered that Maytag was purchased by Whirlpool about a year ago. Further, I know the current models went from a two belt design to a single belt design, and understand there have been problems with getting to full spin speed which I suspect might be partly due to the single belt design. (I see someone recently got a new Dependable Care model, and if I thought I could have, I would have purchased one instead of the Whirlpool!) Well, as it turned out, and as the subject states, I purchased a new Whirlpool washer.
My two requirements in a washer is to have a white tub and an extra rinse option, so I found the a Whirlpool model with those two features. I understand that Whirlpool toploaders don't use belts, and they don't spin/drain, but instead drain, then spin. As I've used this washer, I realize how much I liked the basic-ness of the Maytag. When changing from one phase to another it seems the Whirlpool has longer delays than the Maytag, and the separate drain makes it feel like the cycles are longer overall. Anyway, the question...
On the Maytag, if I wanted to, I could hold the lid switch in, so that I could peek during agitation or spin if I wanted. The Whirlpool doesn't have an externally accessible lid switch. What's the easiest way to get around this? I can crack the lid ever so slightly and barely peek in but not really see much.
Knowing how the Whirlpool works, I know if I raise the lid during the drain, some kind of cam or something activates and when the lid is again lowered, it won't just continue draining, but will drain and spin during the drain phase, then stop and continue on to the spin. Gosh I find that irritating!
Anyway, I've carried on way too far, but would appreciate any information that will help me get around the lid switch.
Thanks!
Thanks!
