Outer Tub Damage on GE FF Washers
When a GE FF washer goes badly out of balance the inner wash basket strikes the outer tub, even on a brand new GE washing its first load of clothing this collision between the porcelain coating on the outer tub and basket can result in enough porcelain being chipped and worn off to expose bare steel which will continue to rust. This design flaw was one of the worst things about GE FF washers, I was always amazed that with all GEs great experience with advanced plastics that they did not install something like Delrin wear strips around the top edge of the inner basket to prevent such damage.
When I do the cabinet swap on the GE DispenseAll washer in our museum I am going to add some Delrin ware strips to the wash basket that I removed from the front bearing of a WP built clothes dryer. The problem of the washers basket striking the outer tub seems to be even worse on the bigger tub 18 pound machines. And while it is easy to re-coat the damaged areas on the outer tub and top of the basket when restoring these washers I do not know of anything that is tough enough to withstand the crashing of the tub into the outer tub, so ones repair may not last if you ever have a severely out of balance load.
