Question on Today's 2/4/21 "Picture of the Day"
parunner58
Apr 18, 2002
844
Davenport, FL
The text mentions a "Semi Automatic". What is the purpose? How did it operate? Like a wringer, set the wash time, then when done come back set it to rapid dry. Does anyone have one or a picture
You have provided your own answer and you are right! The purpose was to save money by not having a timer and possibly permit operation of the machine in a place where there were not permanent connections.
I had one with a pulsamatic transmission.
You turned the taps on and off to fill the tub. There were two control dials.
One was a timer. The other was a four position control knob.
Off
Wash
Spin
Heat
To get the machine to heat, you would put the suds saving ball over the end of the drain hose. Fill the wash tub and then spin the water into the outer tub. You’d set the controller to Heat and the times to hold. When it was hot enough, you switch it to wash, take the suds ball off the end of the hose, and let the water back into the tub.
