Questions about a new Gas water heater install
volsboy1
Oct 31, 2007
756
East Tenn Smoky mountains
My water heater died after 20 years of good service.I busted my ass putting that thing in took my all day to drain the old one and
if anybody has to do this cut off your water and open the drain and pull that emergency blow valve to open otherwise the water
will not drain even if you have your water faucets open.The water heater leaked like hell when I first started to fill it up.I opened
all the water in the house and everything I could think off and still not enough till I opened the blow valve.I could not get the
thing to stop leaking from the cold water in.I remembered a thing about the SR-71 blackbird plane that said that it leaked fuel
when it was cold and on the tarmac but that once it got in the air and heated up it seals it self because of expansion.That seems
to be the same for it so far,I started it up and it has stopped so far no more leaking I just wonder if that is normal?.That was a tough job for me and with no help
my Dad is a Snowbird.He has took off to Florida until March he is a golf nut and spends his time at Saw grass and <span>Tybee Island</span> as long as possible
and leaves me to take care of the rentals,farm,house,and the highlight of it kicking people out when they don't pay.I hate that more than anything I have covered up for some people right now and will get in a huge fight with Dad but this woman has kids and
she is just a little behind it ant like she is some junkie or anything.I really am in a fix with her she is two months behind I am thinking of paying her rent for her to get her caught up.Her transmission went out and she paid to get that fixed I did check with
some folks I know and that was on the up and up.There is over a 100 rentals and I am getting overwhelmed big time with all the
bitching of this and that and I don't know what to do.I have made one choice no more gas or propane I will pay for heat-pumps one way or the other to many druggies cooking s%$ up I think to many fires.These Colemans are failing a lot but they are old. I bought 10 Haier Heat pumps and they work great with that Bristol compressor in them,I know alot of people think Bristol is junk but they and the Haier Heat pumps are working great. I have had one call back on these new installs.
The price was to good to pass up on these units they are doing well I was shocked when you compare price of our Trane unit here for this house I got all ten of those for less than this one unit here.There had been problems with our Trane we had a two stage installed and it fried it self so they gave us the twin compressor 5 ton unit free of charg e.This unit also seems to have some issues with it also it is very loud when heating but not when cooling.That huge two blade fan turns to slow I think cause you can hear it
big time and it is always running it never stops.You can't hear it unless you are in the den then you hear that chop chop noise it is always on though.They tell me that is normal for that unit but my power bill is 230 bucks here this house is 3400+ Sq-Feet or so but with just me here seems high.I know I got off subject it's been a crazy few weeks here and I want to bash my phones because they won't stop ringing.
Take a breath, relax.
Hey, and hit return now and then kind of hard to read your post.  And No there should be zero leaks cold or hot.  The first water tank is the hardest, once you done one or two they come out and go in quickly, I average about an hour.  If your are solder adverse Shark bites or Gator bites make quick work without any need to solder.  I used to hate sweating pipes until I switched to Map gas, much hotter and all my joints come out leak free, work the extra $$.
Leaks and rentals
Leaks are generally bad, but in my (limited) experience, some will self-seal and never give further trouble.
Not sure, but 100 rentals sounds a LOT!!
'Dad' should either be paying you 'proper' dollars to administer that lot, or be paying someone else to share the work.
Give the lady more time to pay, if possible. If she's still a few weeks behind when 'Dad' is due back, you may want to consider helping fund her then.... ;)
Your heart is in the right place :-)
All best
Dave T
