ps91rick
Hi all.. I’m new here.. I picked up a new-to-me ‘87 Maytag LA712 in Almond yesterday — a matched pair with a gas dryer for $75. The original owner who I got them from told me that he started noticing that the clothes were not getting as clean as they used to — and they occasionally had stains. So, I’ve got the front off the machine today and its pretty filthy on the platform that everything is mounted on — what appears to be lines of soot and general grunge. The belts on the bottom of the machine are SUPER loose so they will be replaced.
I ran a couple of quick cycles and the last one, one complete, I found grease on a part of the tub that I know was clean before the last load started. My older brother believes this is caused by the tub seal failing. Does that sound like a fairly reliable diagnosis at this point? I’ll be visiting a local appliance place tomorrow to grab some parts and at his point I’m targeting the following list :
1) belts
2) tab seal & bearing(?)
3) motor rollers
4) spanner wrench
Should there be anything else I need to look at getting? I’ll attach a pic of the bottom showing the soot marks. My brother thought the soot came from the belts but they’re under the plate where the soot came from — so that came from somewhere else. Maybe its associated with the clutch on the bottom of the tub or something.. ??
1) belts
3) motor rollers
4) spanner wrench
