Quick question on “dog dishes”
meldew
Jul 20, 2018
101
Georgia
Can anyone identify with this? Do your clean, sanitized dishes and glasses ever come out of the dishwasher with the aroma of wet dog? I would do almost anything to fix this. I’ve changed dishwashers and detergent. I’ve dried the dishes and let them air dry. Sometimes I have to rewash the whole load. I’ve plastic cups are fine. Right now I’m using a Kitchenaid dw that’s fairly new. It has a hot wash/rinse and a sanitize setting. I alternate finish tablets and cascade or Palmolive liquid with chlorine bleach.
It’s not always noticeable right away but after they sit in the air for a while we notice it. And no no dogs lick the dishes. Nor are dogs even usually indoors.
Any ideas?
Hot water heater?
I’m assuming you’ve already checked/cleaned any filters present in the machine.
Have you considered your hot water heater as the source of the issue? I know of people where their water heater is starting to fail (or the sacrificial rod inside the WH is almost spent) who have had similar odor issues. Once their WH was replaced or serviced (flushed and had he rod replaced) it took care of the odor.
Bob
Do you have an air gap installed?
One of my neighbors told me that their pipes in the kitchen smelled like sulfer. I googled it and got a few hits that basically said that dishwashers could smell if they didn’t have an airgap. And low and behold, I just saw him today and he told me that he had isolated the smell to the bottom of the dishwasher where the filter goes. I asked him if he’d put in an air gap? Nope, not yet.
The previous owner that he bought from several months ago apparently replaced the DW DYI, and didn’t replace the air gap. In our county an air gap is required by code.
HTH
Eddie
I get this once-in-a-while too (maybe once every couple months at most.)  And my dishwasher is installed with an air gap.  It's not terrible and I've never rewashed anything, it's just sort of an off-putting smell instead of the usual faint smell of the Cascade pak.
I only run my dishwasher once-a-week (but in the summer I will run the rinse-only cycle once or twice mid-week.)
I've never figured it out.  When it happens I usually empty the dishwasher and run a rinse cycle with 1/2 cup of straight liquid bleach and then another rinse cycle.  I don't know if this is helping prevent the problem or not.
I suspect it might be some magic combination of the soil on the dishes, my water and the detergent.
Hmmm. I don’t know what an air gap is. Will have to research it. And I have cured it for short spans of time by adding bleach to the washer. And yes I have been fanatical about cleaning the dishwasher filter and interior. I’ve replaced the drain hose and changed the disposal when it broke.
BUT our water heater (tank) is 12 years old. We’ve noticed a drop in hot water volume (I think). I’d say we’ve suffered from dog dishes for several years. We’re on municipal water. But now that y’all mention the incoming water as a source, I remember getting a whiff of the same odor from an older front-load washer! I’ve asked a couple neighbors and they looked at me like I was crazy so it must be us. Tho I once smelled it on a glass at a friend’s house (well water) and I think she was insulted when I asked if they have that same problem.
We’ve never lived in one house this long and have never had to replace a water heater. I guess I’d better start reading up. Thanks I thought about the city water but did not consider the heater!
Melissa, here is just one article about why a dishwasher might smell. It mentions that you either need for the drain hose to have the proper loop in it or an air gap installed so it drains properly. Since you’ve mentioned that you have dogs, maybe if you’ve washed their food bowls in the DW, and the DW isn’t draining properly, the residule water that hasn’t drained may retain a “dog smell”.
See the link below.
Also, here is a page from Walmart showing various DW air gaps.
Also, a You Tube about why you need an air gap.
HTH
Eddie
https://www.walmart.com/search/?que...79416&wl5=9032112&wl6=&wl7=&wl8=&veh=sem[this post was last edited: 8/10/2018-22:01]
http://https//www.washingtonpost.co...ory.html?noredirect=on&utm_term=.8555f29555b9
Thank you. We definitely don’t have an air gap. I will go check the hose to see if it has a high loop. We’ve had a couple Bosches and they made a big deal about the high loop now that I’m reminded of it. I think we’re on our 5th dishwasher in 12 years. We run a few loads a day so not much time sitting there.
I have washed dog bowls in it, but not with human dishes and I always run the sanitize cycle though I’m learning that may not really sanitize everything. And the problem may have predated our dogs. I do run disposal cleaner through. It’s not really sewer gas or food smell. Actually the dishes smell clean at first but then develop the odor, it seems more quickly when it’s humid.
Do you have well water?
As there also is always a little water left in the pump sump, it may have an odor.
If it is draining nearly thoroughly, Try 2 tablespoons of bleach,or even vinegar in the bottom of the machine once you unload it.
Well I’ve been catching up on laundry and outside and just now logged in! Eddie I will watch the video when I get back home. I still haven’t looked at the drain hose!
I have tried adding bleach and that does seem to help. I can try the vinegar too.
No I never even thought about a commercial dishwasher. I didn’t know they would fit in my small kitchen. Our first in this current house was a Frigidaire - and I didn’t like it. It left so much debris on the dishes. Then a Bosch that I liked and I don’t remember what happened. A whirlpool which was fine. Then another Bosch which was a good washer but the racks were corroding/rusting and then it completely broke and the repairman said it would be an expensive repair and just replace it. So I got the Kitchenaid sight unseen from a scratch and dent store a ways away. It’s fine.
I had repairmen our for the smell. They assured me the dishwasher was installed correctly. I think was when I had one of the Bosch.
I’ll get back to y’all on the drain hose configuration. And I can call someone to ask about the air gap.
One tip off your water heater is going is white chunks collecting on the aerators at various faucets.  Replacing an anode rid is cheap and can get many more years out of a tank if done as needed.  If the tank has issues, how does the water in your showers smell?  If it's fine I'd rule that out as the issue with the DW.
Smelly Bosch DW
Hi, I would use a little liquid detergent with chlorine bleach in every load in the pre-wash cup or just put a tablespoon or two on the inside of the door each time you run a load [ and always use a premium DW tablet in the main dispenser cup as well ].
We get a lot of complaints about this with Bosch and other DWs as well that do not have real drying heating elements in the bottom of the DW.
An air-gap will not help this problem and in fact they can lead to odors in the kitchen area due to the gunk that collects in the [ open at both ends ] hose that connects the AG to the disposer or tee pipe above the trap.
The original post states that she is using a Kitchenaid DW John. But my neigbors that are having a problem with their DW smelling do have a Bosch. I’ll pass your suggestion on to them about using a drop of liquid detergent in the pre wash cup andbsome LCB in the bottom. I believe that they are already using a premium DW detergent pak.
Eddie
curveball...
...but the only times we have noticed bad smells from the dishwasher / crockery (especially glasses) is when any amount of EGG residue is left on the dirty dishes. Therefore we always pre rinse eggy items by hand now. I wonder if egg could be your culprit too?! Hope you get it sorted. Nick
Egg...
I also confirm that eggy dishes, in any form, seem to taint the load. Noticeable on glassware and crockery, as these are the items that come closest to the nose.
So I rinse.
Maybe a trace of egg left on dishes, but I use Finish complete tabs for the main wash, Cascade gel with bleach for the pre wash. Never any odors.
Ditto on eggs
I, too, have found that eggs can leave dishes smelly - although not always.
Cannot comment on the air gap situation as we don't have these things over here (nor have I ever needed to high-loop a drain hose).
