Random Musings On The LavaTherm Dryer
launderess
Jul 22, 2004
20,645
Did a small load of darks last night in the Miele and decided what the heck, time to try out the other new arrival. Since the place had been shut up with the AC on for a few hours it was cool enough with dry air. Figured for the short time it would take to dry the load it was better to use the condenser dryer than to open window to insert vent for the Whirlpool compact dryer.
Didn't bother with snaps as have posted pics of the dryer before and there really isn't much to see when it operational with the solid door and all.
Anywho am quite underwhelmed with condenser drying, well at least this version anyway.
Load consisted of 1 pair of sweatpants and three dark T-Shirts all black and made from cotton. Used the timed dry setting as the AEG LavaTherm manual seems to suggest this if one is drying <1Kg which this load certainly fit.
Set timer to 20 minutes and pressed start, then went off about my business. After about ten minutes went back to check on things. Popped open the door and yes, there was the "hot" but moist laundry those who use condenser dryers speak of, but items still were not "dry". Closed the door and restarted the machine. Apparently the last ten minutes of all drying cycles timed or sensor, Cottons or "EasyCares", etc... is the cool down phase without heat. So choosing timed dry of 20mins only gives 10 of heating. This wasn't a huge deal at first because there was still a lot of heat inside the dryer (so one thought) and it would be enough to dry things.
Not a bit of it.
Items came out of the dryer warm and damp. By this time things were starting to get a bit warm indoors so decided enough was enough; hung up the moist wash on drying rack and ended the trial run. Cleaned the lint trap of minimal fluff, and emptied the water container (well took it out and held it over the sink as it was empty).
Thoughts? The compact Whirlpool dryer would have had this load almost totally dry in 20mins. While the hems and or elastic waistband of the sweatpants may have still be damp, everything else would be dry if not crisp. All this with using *only* 1450w of heating power versus the 2300w or so of the AEG.
Every so often the Lavatherm would stop, pause then restart. At first this caused concern, then figured out this dryer has a reverse feature and that is what it was doing. Also don't know if it is whatever laundry detergent and or fabric softener previous owners used, but it scented not only the load and wafted through the home as well. Even now many hours later the laundry still has that whiff about it. Used unscented detergent so the scent is very pronounced.
All and all cannot say this will be one's go to dryer. Aside from having a larger drum then the Whirlpool and reversing it just does not seem very efficient or fast. There is a "Quick" button/option but the manual is rather vague as to what that does.
AEG dryers were and still are s-l-o-w, in my opinion. Our consumer magazine tested many AEG dryers and they were always on the slow side. Only recently, they tested heat-pump dryers: the AEG took 3:15 hrs to dry an 18 lbs. load, while a Bosch only took two hours ("only"by heat-pump dryer standards). I know that today's AEG units are just Electrolux units, but even our true German AEG we once had wasn't speedy.
In the 90s, we had a true AEG dryer that had a similar design like yours. Well, one day, something went wrong and we called for service. The guy took the back panel off (very easy) and... lint! Lint everywhere; hard, baked-on lint! I couldn't believe it, as we always cleaned the dryer. Turned out that the design was such that it would let a fair amount of lint bypass the filter and enter the condenser and heating channel of the dryer. :-( No wonder, Electrolux added a second lint filter when they took over.
RE: the quick button. I could imagine it doing two things. Our Electrolux dryer uses a technology very similar to Soft Heat - turning one element off as soon as clothes reach a certain dryness level. Our Lux turns the heat to low when clothes become Cupboard Dry, my Bosch does it as soon as clothes are Iron Dry. Quick might disable the Soft Heat. On the Lux, Quick also reduces the cool down to five minutes.
Here's how I cleaned our old Lux. Most dryers have similar panels on their back.
Alex
A few of my thoughts on this:
I never bother with the timed cycles, not even with small loads. Both my AEG vented dryer and the Miele condenser don't have problems drying a small load on an automatic programme.
Stopping a condenser dryer mid cycle is not exactly helping the drying process. The dryer needs to build up the humidity level again in order being able to condense the moisture in the machine.
Condenser dryers are always slower than vented dryers.
I use my condenser dryer in the winter and the vented one in the summer. Best of both worlds!
Air-cooled Condenser Dryers
Louis has it about right I would only use a condenser dryer in the winter, they are always slower and use around 25% more electricity to do the job. I have lost count of how many European dryers I have sent to the crusher still in working condition [ condenser and vented ] It is amazing when WPs smallest 120volt dryer can out perform a NEW European dryer.
Cimberlic if space is tight I have for sale both the 240 volt and gas versions of your little WP dryer, with one of these higher powered dryers you could dry clothing almost twice as fast as your portable.
Thanks Combo, But I'm Good Dryer Wise For Now
Really need one of those vintage chrome stack dryer stands. I know you've got one lying about up there! *LOL*
@Loggix,
Great vid, it has been bookmarked for future reference. Seeing what light to nil use these units have had, don't see the need for a "tear down" just yet. If one uses the dryer more than a handful of times over the cooler months will consider doing a heavy duty cleaning next summer.
As things stand often take large and or bulky items around the corner to the Laundromat. Combination of high final spin (Miele, spin dryer or now the AEG) and those hot gas dryers make for fast and cheap work.
@Louis,
Thanks for the tips. Will use one of the automatic settings next time. Yes, shouldn't have opened the door often, but being one's first time.....
matrix "block"must be clean
I have noticed with my asko air-cooled condenser that drying performance really drops off once the condensing matrix gets linted up-I usually check it every 10-15 loads-easy to check and clean on the asko.
Quick Button
May equal something along Miele's "Turbo" option for their condenser dryers. That selection gives normal heater operation but temperature is set higher which one presumes gives faster drying.
According to the manual the QUICK BUTTON gives "normal drying in a shortened cycle time". That it cannot be used with "Special Care" (low heat drying for sensitive fabrics) or Hand/Machine IRON tells me it is meant to provide a faster and less monitored drying. That is you won't be bothered if items are "dry" versus various levels of damp for ironing or whatnot.
For some reason those chrome stands are everywhere in Canada, but very hard to find in the USA. Each time one does come across they are mated to a set and either one has missed or seller refuses to spilt items for individual sale.
Just feel the metal/chrome racks are more stylish and IMHO a bit more sturdy than the newest incarnation from Whirlpool.
Having leveled and slid the AEG into place can see how really only the open floor area of the older stands works for my situation. Have placed those "slider" pads under each foot of the AEG to make moving it a bit easier, such as for cleaning or whatever. The newer racks have those guides at the base which one supposes is fine for portable washers with casters, but not for us.
Soon as new dryer hose arrives for the Whirlpool (while it was being swapped out give it a good cleaning and decided to ditch the periscope deflector and replace vent hose), will stack it on top of the AEG and that will be that until the desired rack can be sourced. To protect the to of the AEG will either lay down cork tiles with a non-slip mat over, or just purchase one of those appliance "stack mats" and be done.
Thought We Were All Mates?
Spent nearly two hours hunched over bathtub cleaning the most horrible gunk out of the AEG condenser exchanger. Why didn't you lot warn me about this? Am here to tell you if one is going to have to do that again anytime soon then this dryer shall see little use.
Didn't want to use it anyway but went for the Whirlpool and after going to place the hose and vent cover into window realized the darn thing wouldn't reach. It is my own fault as had purchased a new "semi-rigid" hose to replace the old foil in preparation for stacking the unit onto the AEG. IIRC the old hose was about eight feet, and the new about four, so that was the end of that.
As the weather has been rather nice these past few days (cool and no humidity), what with it being a cool late night and all figured would give the AEG a try. So in went four sheets, set the unit to "machine dry", pressed start and got on with other things. Came back when the dryer signaled it was done to see the "condenser" indicator light on, and as according to manual removed the thing for cleaning. That is where my troubles started.
Placed the unit in the bathtub, aimed shower hose and the gunk just kept coming. Hair, lint, fluff and God only knows what; but wait there is more. Even after fifteen minutes of rinsing there was *STILL* more gunk inside. It took almost two hours in total of rinsing, drenching, soaking and even using a thin credit card to dislodge most of the gunk and leave the unit 99% clean. This I cannot have, so a work around or routine is going to need development. Have never seen such a thing, in all my experience.
A few more niggles. The "empty water" light comes on at the end of each cycle, but thus far the container is empty. Indeed did three loads of sheets (the Miele can only hold four king sized sheets max at a go), and nothing, not a drop of water. Did peek towards the back of the condenser chamber before reinserting and the spot where unit drains into was clear. Is this normal? Dryer operates fine otherwise.
Sateen sheets done to "machine dry" came out hot and damp even after 10 minute "cool down", but once hung up they dried out to barely damp within several minutes. All ready for the Pfaff ironer.
Will say one does notice a difference between sheets dried in condenser dryer versus the Whirlpool or even those huge Laundromat gas dryers. Things feel "different", cannot put my finger on what it is, but it is something.
Launderess
one thing I have learned over the years of condenser dryers is it is very important to keep all airways as clean as you can, for instance its a good idea to wash in soapy water all filters as they clog easily, one reason you may have an empty water tank is not enough water in the system to get pumped up it may take a good load of towels to prime the pump etc as long as you do not find any water anywhere I would not worry.
One thing I noticed is all fabrics seem plumped up a little so feel softer.
Good luck.
Austin
Apparently the AEG condenser needs more often cleaning than my Miele. The times I cleaned it in the 16 years I have it, can be counted on one hand. Recently took it out, almost nothing there to clean.
One of the reason for not finding any water in the container might be that it is set up for draining in a drain pipe. You might find some water behind the dryer if that is the case. Look in the manual how to change it back if that is what it is set for.
Thanks Lads
Checked with AEG manual on how to determine if unit is set to drain or drawer as it were, and yes the unit is set to drawer. No water behind unit around the area where the drain hose leaves.
While the condenser unit was drying using several microfiber dust cloths cleaned the chamber of lint both dry and wet. After sorting that mess out gave the lint filter screen a quick washing.
@Louis,
Methinks Miele dryers have two lint filters or at least a better system than the AEG. IIRC recent Lavatherm models use both a door mounted filter and one under the porthole, mine does not. This probably accounts for the amount of lint and muck both on the condenser unit and in the chamber. Prolly explains the amount that builds up inside the dryer with years of use as well.
It might be previous owners never bothered cleaning the condenser during what appears to be their short period of ownership. It may be gilding the lily but perhaps a more frequent cleaning schedule will keep the gunk factor in check.
It maybe that the "Clean Filter" and "Empty Water" light comes on at the end of the cycle regardless, just as a reminder. Will see the next laundry day before winter that is cool enough and dry a heavy load of towels to "prime" the condenser pump as Ozzie recommends.
Lavatherm
Glad you are getting stuck in to the dryer, yes welcome to the world of even higher maintenance, if you are getting so much gunk on the condenser please check that all the seals and rubber gaskets from the door to the box are tight and are sealing well.
This is the main cause of premature breakdown of these condenser dryers, am just about to do a thread on a Hotpoint Creda condenser that I just revamped, the condenser box seals had gone and allowed detritus and steam to flow throughout the dryer, which in turn coated the whole of the working insides with conditioner wax gunk AND broke down all the other internal seals...many repair men would just replace the seals and would not have the time to take apart and clean every sticky icky part - probably just write it off...
Like others have said, use your max spin extract or spinner, always select the AUTOMATIC DRY programme, let the computer work out the settings, and DO NOT open the door to CHECK HOW DRY - just messes up the timings....Dont be put off by it, these dryers do (as you know) work much better in a cool / cold environment.
Venting Compact Dryers
Laundress what type of flexible vent tubing did you get for the WP dryer, if it is the horrible flexible aluminum tubing it usually comes in 4 foot lengths and it is designed to be stretched to 8 feet.
I have not seen your dryers setup but for a compact dryer where you are using a window vent you are probably much better off with high quality flexible plastic ducting designed for clothes dryers.
Dryer Flex
Is the brand hose fitted onto the WP. Looked at the "new" flexible plastic vent hoses but has one has been warned off such things for ages didn't give them a second thought.
Previously had used one of those ghastly periscope things to get unit closer to wall, but found even when all seams are sealed with duct tape dust/lint still leaked out everywhere. It went into the trash along with old vent hose, and you wouldn't believe the amount of lint "caught" inside the thing.
From the colour of the muck washed out of the condenser previous owner had longish blonde or light brown hair and wore lots of dark coloured items. *LOL* Says this after being rather intimately involved with the stuff for hours cleaning the coil and chamber.
L, I have the very same AEG dryer. Sorry for being late here. I should have warned you to make sure the condenser unit is clean and lint free. It does build up with time. The condenser light will come on when the machine senses it needs cleaning. I do mine outside with the garden hose and spray nozzle. I concur with the others who say to use the automatic drying cycles. I always choose the very dry setting and everything comes out nice. The only fabrics I have trouble in it are permanent press shirts which come out very wrinkled for some reason. You will appreciate it in winter.
