This home I acquired some 24 years ago has a regular kitchen, and another kitchen inside an attached enclosed patio.
The patio kitchen came with a nearly pristine Frigidaire Compact 30 slide in range. It works fine, although I'm not sure of the little clock/timer. I have never used the oven part, just occasionally the burners, and not for quite a few years.
I confess I do not like electric burners. Electric ovens are OK, but sort of a PITA with current electricity restrictions in our state. (I signed up for lower rates by reducing electricity consumption between the hours of 5-8 pm M-F).
Over the years I have acquired three candidates to replace the Compact 30. As I recall, I even had a plumber install a gas line extension to the area under the house closest to the patio kitchen range location. But I'll have to crawl under the house to refresh my memory on that ;-).
Anyway, the candidates to replace the Compact 30 are:
1) Gas GE Profile 30 inch slide-in, with ceramic type top and gas burners. White.
2) Gas Kitchenaid Superba, with convection, 30 inch slide-in. Gas burners. White.
3) Modern Maid 30 inch slide in gas range, with "Electro Pilot" feature (which I assume means it has spark type igniters). Sort of a brown.
I haven't tested any of these ranges, yet.
Offhand, I am wondering if anyone has any opinions about these ranges. The Modern Maid is probably the oldest. The Kitchenaid Superba is probably the most functional, since it came out of a home next door as they remodeled, and I'm told it worked fine. Don't know about the KA Superba or the Modern Maid functionality.
One reason why I want to replace the Compact 30 is because currently the main house kitchen, which was probably built with a gas range in mind in 1941, was remodeled in the 60's, and converted to an electric GE P*7 wall oven and a Corning electric cooktop on a nearby counter. I replaced the Corning cooktop with a Frigidaire Gallery "Gas on Glass" cooktop about 20 years ago. It works well enough, and saves on electricity as well.
So, anybody have a favorite among the three gas range choices listed above? GE, KA Superba, or Modern Maid?
And no, I don't want to get rid of the Compact 30. It might find its way into the workshop (where I also have a Tappan electric range I have used for baking powder coating onto car parts).
