RCA Whirlpool matching washer/dryer set
sudsmaster
Dec 23, 2004
15,034
SF Bay Area, California
I'm going to look at a matching old RCA Whirlpool "Supreme" matching set tonite. Turquoise, with lighted control panels. Will post photos later after I see them. The design looks like it could be 60's or 70's, not sure when RCA divested itself of Whirlpool.
I'm assuming the washer is a belt drive type, similar to the design they had until the direct drive shredmores of the 90's.
I like that they are a matching set, in pretty good shape, with lighted panels. So far I have GE, Maytag, and Frigidaire (sort of modern front loader) in my growing collection, so this would certainly broaden it.
Not so hot about turquoise, but since they're going on display in the workshop it won't be an issue.
Anybody care to comment?
Turquoise . . .
Ah, but goatfarmer is right: anything turquoise is good! It is my favorite of all the classic appliance colors, even better than pank.
I am pretty sure that any set in turquoise is unlikely to be '70s, as once avacado green and harvest gold came in during the late '60s the turquoise disappeared . . . sigh . . .
As far as I know, RCA never owned Whirlpool but rather the name was used as a marketing agreement . . . someone please correct me if I'm wrong! My grandmother had a wonderful RCA Whirlpool bottom-freezer refrigerator in yellow, which matched her Frigidaire Pulsamatic in the same color.
Good luck with your find!
I confess I prefer plain appliance white for vintage washers/stoves/fridges etc. Has a nice clean look, easier to touch up, goes with just about any other color, doesn't show dents or dust a readily, etc.
Although I'd have to say that the old 60's Frigidaire washers looked pretty good in turquoise, maybe even better than in white.
Any comments on the old Whirlpool washer mechanism of the 60's?
Turquoise Whirlpool
This matching set is being advertised on Craigslist San Francisco. There is also another listing for a bottom of the line Kenmore washer probably from the mid 60's that is being offered for free in Petaluma about 40 minutes north of San Francisco. The Kenmore works.
I got the RCA Whirlpool set... the washer is a Supreme 80, Model number LPA780. I'll upload some photos as soon as I can.
I don't think the control panel is back-lighted, but it's possible that the bulb is burned out, or it can be retrofitted for back lighting.
Rich, you hit te mother lode!! These are darn nice and beautiful. The two-speed dryer rocks!! Infinite dryer heat temps. Yes, the washer lid instructions ARE easy to follow. And the WnW cycle shifts to gentle speed at the 4 minute mark!!! Now I gotta go find another cigarette!!! whew!!!
Thanks, Bob! I'm completely exhausted. Truck got a flat on the way home (and that's the short version), so didn't get home until past 11 pm.
This weekend I'll try plugging the washer in to see if it will run a full cycle (gotta go get some cold water Tide!!!) without dripping or spewing grease all over the neighborhood. I *think* I have a suitable 220 outlet in the workshop to plug the dryer into, but not completely sure at this point. If not the main house has one, but it would be a tight fit (and nowhere to send the exhaust except out the door).
Hey Bob, no problem. I tried jacking up the truck twice with the silly little twirly jack that comes with a '78 Dodge D100 truck. It worked just fine, except it couldn't get the tire off the ground. Tried it twice. Then found a pay phone and called Triple-A and the seller. They showed up at the same time, AAA with a real jack and the seller with some water and cookies. LOL.
I'm a little embarrassed about how I got the flat... I got lost in the city I grew up in (although I have never been real familiar with that area). I wound up making a U turn and ground a front tire against a high curb (I was hoping the wheel would climb the curb instead of grind it). Quite a few blocks later, still lost, the tire blew. With a cartoon classic POP! and then a "Peeeeeeeeuuuuuuuu!". Quite a night. But I made it home ok and now it's time for bed even though I'm too amped to sleep.
Kewl set! LPA/LPE/LPI is 1965-1966ish, I think. We had an LME-4600 dryer, bought in 1964.
Two speeds on the dryer refers to airflow rate, not tumble speed. If it's a belt-drive blower design, the blower pulley is two speed with the belt being moved by a shift arm mechanically operated by a cable on the speed control. If it's the direct-drive blower design, airflow rate is controlled by a damper door in the exhaust system. I'm not sure if Whirlpool may also at some point in time have included a dual-stage heating element or gas burner as part of the two speed feature.
Super Wash runs a 2, 4, or 6 minute prewash, a pause for two mins (one timer increment), a partial drain (until the pressure switch resets) with pause for remainder of the drain increment, then continues on through the Normal cycle. Usage instructions called for 1-1/2 to 2x detergent dosage for Super Wash. Imperial models of the time included Super Wash on Wash-n-Wear (later Perm Press) as well. Notice there's a larger "Off" section in front of W-n-W. The timer cams may include the sequence for Super Wash there, but it isn't electrically active.
