777littlebit
Member
I'm hoping someone knows a trick that will help me to get the agitator off of a machine I inherited. I've put straps (o.k. webbing type dog leashes) under the agitator and tightened the assembly .. left, right & repeat. I moved the straps and did the same. Sadly it hasn't budged. On the up side it has broken yet either. I've left it under tension and added vinegar to see if that might help dissolve some of the particles helping to hold it in place.
I'm including pictures of how I've got it rigged.
I don't own the proper tool for removing this. I'm not sure it would do any better than my rigging. If one of you has used the proper tool and has input, I'd be delighted to listen. Or if anyone has any suggestions I'd appreciate those too! Thanks to all of you.
