Replacing bearings on Whirlpool WFW9600
I've run a number of loads through the unit now and all seems well.  In thinking about the rubber squeak now I wish I had put a light layer of silicon lube on the seals, odds are that would have stopped the noise.
LUBRACTING THE WATER SEAL
You may be correct about the squeak coming from the water seal, I always grease the lip type water seals on washers FL & TL alike with a good quality grease. But in any event you have done an outstanding job saving a good washer from the crusher, your efforts will inspire many others to do the same. We are still in a learning curve with the newer Hi-Efficiency washers, but I have no dough that with the excellent quality control that is used in the production of new appliances today that many of these machines will easily be used 20-30 years.
Yup, I had the same thought!
Odds are there will be a few around in 20 years, then herd get's thinned early on, I think if it makes it to the 10 year mark, with routine work it should last.  I've got an 8 or 9 year old duet that is still doing well, picked it up last year cheap because it needed a new pump.  it became my daily driver, and I've given it a lot of use. I'll give this one a few more weeks of use and odds are I'll list the older one on CL.
