Farberware's heavy aluminum base is more than electroplated to the stainless. They used a heat process to bond the aluminum to the stainless steel. If the pans were seriously overheated, the base would separate and stick to an electric surface unit. I remember the manager of the housewares department telling us how in the 1950s, when "waterless" cookware was all the rage, Farberware said that vegetables could be cooked the "waterless" way in their pans. A woman came into the housewares department with the 8" egg poacher skillet, but without the aluminum base. They politely asked her what the hell she had done to the pan. She explained that since Farberware could do "waterless" cooking, she had tried to poach eggs without any water in the bottom of the pan. One big disadvantage to Farber pans other than the skillets, at least in the original design, was that the base of the pans is concave when cool. The arch flattens out when heated, but if you are boiling water the base does not heat up enough to flatten completely so it's not as efficient on an electric unit. The skillets heat up enough in normal use to flatten perfectly. I really like the Revere Ware with the thick aluminum base. They sit flat on a surface unit and distribute the heat very evenly. I use two of the 4 qt. saucepans for making candy and they perform beautifully. I brought all of the family's old Revere to my house when we sold the house. I loved using the 12" chicken fryer. It was great for stewing squash and onions, but the heat had to be kept on low to keep it from sticking.
The thing that did in Revere Copper and Brass works was the damn aluminum ore mines one company president bought. The cost of operating the mines bled the company dry and no attempt at aluminum cookware got off the ground. I remember when the price of copper went so high starting in the mid 60s and to save money, Revere came out with the "deep drawn" saucepans in the late 60s. The narrower diameter of the 1.5 and 2 quart saucepans meant they could use less copper. The narrower pans did not cover a 6 inch surface unit nor did they allow much of a flame under them because it would spread out and go right up the side if turned higher. It is very unfortunate that such a prestigious company was forced to take such measures.
One of the rarest pieces of Revere Ware has to be the deep well kettle they introduced in 1941. Unil I saw some post-war literature, I had no idea that it even went into production, let alone continued into the later 1940s. So far, I have managed, over the years, to find the pieces that interested me so I guess that sometime one of these will be sent into my life.
