If ducted heating was something of a necessity where I lived (it *IS* where I've just moved to), then yes, it would be a sensible idea just to prevent hot/cold spots.
One thing I don't like heating "just one room" with room-heater devices like mini-splits is you end up with cold hallways, hot rooms and anything in between. No thanks.
In the summertime, with refrigerated A/C, the fan is never set to continuous as even in the dryest weather, it substantially increases the humidity in the house from 35-40% to anywhere north of 45%. This significantly reduces comfort when the A/C is kept at a higher temperature such as 80ºF.
In this situation, using a small desk fan is favourable if you need the continuous air movement.
The other thing was that we setup our central A/C to push more air to the bedrooms, which tend to stay warm otherwise. They now keep up to a 1-2º cooler than the lounge/kitchen/dining where the thermostat is*. Added benefit is that the system doesn't short cycle as much and the longer running times keep things dryer as a result. We'll just ignore that it increases the noise level from a deep rumble and "rattle" in the vents to something that sounds like an arctic storm howling in the lounge.**
In the new (old) house I'm in back in the city, we have ducted evaporative A/C. No choice but to have continuous fanning, although the system works far better than I remember evaporative cooling. Added benefit is house naturally stays fresh due to the continuous fresh air intake, so odours are easily expelled from the house as a result.
Wood-fired heating, as is typical in many parts of Australia.
Phew, what a post.
*Thermostat should've been in the hallway where the returns are, not in the central living area that one huge wall outlet and a smaller ceiling outlet for the kitchen.
** If I ever got my hands on the idiots that designed that system...
