I'd rather see manufacturer's fit a more durable shaft seal than putting prices up by going back to non-welded tubs. In my experience, it is almost always the shaft seal that fails before the bearings, and hard water seems to make the seal fail much sooner, I believe because the lips on the rubber seal can't flex once they get encrusted with hard limescale, and with the water level being quite low, even descaling it doesn't get it all off.
I'm no expert, but possibly a "Cassette Seal" might last longer.
I wonder what percentage of splitable tub machines were actually being repaired before welding became popular. Unless a machine is still in guarantee when the bearings start to go, I'd expect most people would run it into the ground until the noise became unbearable, the electronics refused to spin anymore, the door seal started smoking, or something broke.
By the time the bearings fail, the machine is likely to be at least 7 years old or had very heavy use, unless it is a complete POS, or has been abused. If you opt to get a professional repair, you've got a call out fee( likely £100 - £150 here in the UK) which will just cover diagnosis, plus I would expect about 3 hours labour, plus the price of parts. And on top that you may well have to take the day off work to let the repairman in and could be over a week without a machine, if he's busy. And even then, being old, if you get unlucky, the machine might breakdown with another fault in a few months time.
It only really makes sense these days, if you are prepared to do it yourself, and if you DIY, even a sealed tub is not insurmountable. * (Although I'd not use silicone, either weld or use a polypropylene adhesive. )
I think most people would opt to buy a nice and shiny new machine, with lots of brand new, although possibly pointless, extra features and more importantly a decent length guarantee. Might well be cheaper too.
As a keen DIYer, I'm not a fan of sealed tubs either, but consider them practically inevitable to allow manufacturer's to keep cost down, If he got his way and banned them it would simply push manufacturers to move production to cut labour costs.
I'd commented in that YT video [
link here] and one of his previous about the cost savings and reducing the number of parts and assembly steps in production, although henene4 explains it better here, but it didn't go down very well
Someone made a very good point in one of his other videos, that even if a manufacturer was to use a machine to put all the screws in at once, it is still likely to be slower than an ultrasonic welder and it would be far more costly to buy and maintain the machinery and would need more frequent maintenance to ensure it works properly and achieves the correct torque.
