Sears Kenmore Belt-drive Transmission Rebuild
Well I got the seal and spring but misplaced my smaller spring Im annoyed on the fork assembly.Would you know a P/N cant find anything.I know the older transmissions didnt use them at all as I think it was an upgade. Looks to be the same wire thickness .105 but two coils shorter then the main agitator spring. Anyhelp would be appreciated ...Glenn
The spring PN for the fork is 16015, still readily available and all over eBay.
Fun fact - that PN is the original PN for that particular spring, going back to the first belt drive transmission in 1947. It is one of the very few items starting with 16xxx that remained through the last of the belt drives in the late 80's.
There was a brief period from 1959 thru 1964 where Whirlpool omitted the 16015 spring, in favor of the agitator shaft seal spring, 92815, and a revised fork that no longer interfaced with the lower section of the gear case. The updated agitator shaft spring was intended to replace the tension needed to hold the gear securely in place, but thankfully Whirlpool went back to the full length fork and the original 16015 spring paired with the new agitator shaft seal/spring assembly with the heavy duty gear case revisions in '64.
Ben
You need 80 to 90W gear oil, that’s what I put in mine when I rebuilt the transmission back in the spring of 2021. Has been holding up so far.
Have another Whirlpool transmission I plan on rebuilding at some point, however I am going to experiment with putting corn head grease in than one since corn head grease turns into a heavy gear oil when mixed around, turns into a grease once it settles.
