bureaucrazy
Member
Progress...
For anyone else who needs to do this, you should lay the machine on it's back and use a screwdriver to remove the 4 crosshead bolts holding the case to the chasis. Then remove the nut and bolt under neath the front. Then get someone to help stand it up again. If on your own, you should lay it on it's front and undo to nut and bolt and the two forward most crosshead bolts. Then stand it up and undo the rear bolts with a short handle spanner or special angle screwdriver that can reach in and under.
Once standing up, you can carefully remove all stuff attached inside the body and then lift it off.
Ok, so I've removed the body without having to disconnect any gubbins.
The front of the drum is now accessible.
However, there is a lot of gubbins dangling around the top and back such as the soap box and the top back panel, etc.
I don't know how awkward changing the bearings will br or how much force is required to remove them, etc. Will I need to lay the machine on it's front or back during the operation?
Before I go further, is it better to remove the loose gubbins and then try to remember how it goes back together or do you think it would be OK to just tie it and tape it in place so it stays put while I work on the drum?
