I just lay it on its side on a towel or blanket and then tip it right over its not going to take long to oil the spinner bearing and don't for get the pump you will be surprised how much quieter it will be.
Easily able to get to the pump bearing although I had a bit of an issue getting to the main spin bearing as it is underneath a dome/cup shaped pulley So what should I do in regard to that?
You could if you felt brave enough remove the spin pulley to allow you to get to the bearing, Or spray it with aerosol oil which may help but won't be as long lasting. If you are going to remove the dome pulley put the machine on its side so as to prevent oil spillage from the gearbox when you have it removed you can up end it to oil it.
Hi Adam there is a pin through the pulley that you have to remove it may take a bit of persuasion to get it off but they are pretty solid so a bang or 2 with a hammer often does it.
I found out how to oil the bearing without taking the pulley off as there are four slots in the pulley
So I just squirted tomorrow and they rotated around quite a bit and it appears to be a little bit quieter I’ll have to test that with the YouTube video tomorrow
You might want to leave that as long as you can because trust me its not an easy fix, It can be done but you need the right bearings and a new seal and a lot of hard work, you have to remove the wash deck as the spin can only comes out the top. I and a few other have done it and its a long hard slog. Getting the new parts will be a beast of a job too.
