Sheet metal in bottom-freezer refrigerator
wendy
Active member
Aug 1, 2024
34
new england
There's a piece of sheet metal lying directly on the coils of the freezer compartment of my GE PDS18SBMALBS. Is that right? I can't tell from the parts diagram.
Hi Wendy, there is an aluminum sheet laying directly on the evaporator of your refrigerator, that’s the way it was built and needs to stay
The aluminum helps trap the heat from the heater in the middle of the evaporator that defrosts it. It also protects the Styrofoam insulation above the aluminum sheet from the intense heat of the red hot heating element.
This aluminum sheet is very important not only makes the evaporator defrost properly, but also protects the plastic parts above the evaporator from severe damage from heat or possible fire.
John L
Thanks a lot for confirming that; makes sense. I'm out of things to try to keep the crisper drawers from running too cold--things at the bottom of both drawers start to freeze, although higher up in the drawers is OK. I suppose something is wrong with the airflow, but I'll be damned if I can figure out what it is.
Hi Wendy, can you post a picture of the insulation you’ve added above the plastic floor of the refrigerator?
I’ve had many customers with the problem of freezing stuff in the crisper drawers at the bottom and we’ve always been able to solve it by adding adequate insulation sheet, there’s just no way things are still gonna freeze if you insulate it properly
John L
Here you go. It's foil-wrapped. Could that be causing it not to insulate properly in this instance? I suppose I could try a different kind of insulation.
    141.9 KB
I don't remember the R value, but it can't be very high because it's quite thin. In fact, I actually do have three layers folded. By flexible closed cell foam I take it you mean something like pipe wrap but flat. I could try that.
I notice cold air escaping from the sides and back of the Styrofoam under the FF floor. Should I block all that in as best I can with strips of Styrofoam or the closed cell foam? And I wonder if as a last resort I could raise the drawers one notch by raising the shelf they hang off of. A small waste of space, but if it lets the drawers be in use again....
Thanks for your ideas and expertise.
Could you possibly point me to the kind of insulation you're recommending at, say, Lowe's or Home Depot or Ace Hardware, all of which would be easiest for me to pick something up quickly? Thanks again, in advance this time.
How about this for insulation, a flexible sheet: https://www.ebay.com/itm/386724835005 ?
Should I run it slightly up the sides and rear as well as under the crisper drawers?
And what about the spaces to the side and rear of the Styrofoam at the top of the freezer compartment? Are they part of the airflow system and should be left open, or do I fill them too?
Hi, What's the R value of that insulation sheet, my guess is that you may need 2 or 3 layers of that insulation sheet.
We have usually used a flexible closed cell foam at least 1/2" thick
I really don't get it. At this point I don't think improving the insulation under the drawers will help, even that flexible sheet I see on eBay, which I think is like pipe insulation and would probably b be better than what I'm using now, but still....
When the compressor is working, I feel cold air coming up into the FF compartment, most notably from the rear of the floor, especially in the center, right over the fan. I believe there's an opening above the fan that must be the channel that brings the air to the top of the FF area. I don't recall any special insulation around that area, although at this point I've been in and out of there so often I can't say. Air does get to the top of the FF area for distribution there, so I don't think there's a blockage. Or could it be partly blocked? Although I don't know how something could have gotten in there to block it. Could there be something wrong with the temperature controls?
Should I put insulation around the area above the fan, just outside the opening into the channel, beyond the Styrofoam sheet that covers almost everything? And what of the sides, where there's a gap of 1/2" or so between the Styrofoam and the freezer wall? Is that OK or should I stuff something in those areas? What about the front and back edges of the Styrofoam? Should they be taped down, perhaps? I don't know how isolated I should be trying to make the whole area.
I'm flailing here, because I just can't figure this out.
Any ideas?
