wendy
Active member
There's a piece of sheet metal lying directly on the coils of the freezer compartment of my GE PDS18SBMALBS. Is that right? I can't tell from the parts diagram.
Hi, What's the R value of that insulation sheet, my guess is that you may need 2 or 3 layers of that insulation sheet.
We have usually used a flexible closed cell foam at least 1/2" thick
My latest thinking. Can anyone help? Here are photos:I really don't get it. At this point I don't think improving the insulation under the drawers will help, even that flexible sheet I see on eBay, which I think is like pipe insulation and would probably b be better than what I'm using now, but still....
Will you please look at the photos I just posted, with my further thinking as I search for an explanation of what's wrong with this refrigerator? I think this is something that falls into your area of great experience and wisdom.Hi, What's the R value of that insulation sheet, my guess is that you may need 2 or 3 layers of that insulation sheet.
I take it you don't think it likely that the fan is weak--it does a good job of pushing air, I guess. Actually, the FF seems to be getting too cold even with the setting down to 2. I wonder if the temperature settings could be faulty.Hi Wendy, thanks for posting all the great photos.
It certainly would not hurt to put some sort of rope tight caulking in that gap right above the fan in the floor of the refrigerator if cold air seems to be coming out of that crack that should not be the case.
I would probably use some sort of flexible, caulking, like people put around windows and things that can be pulled out in case you ever have to service the fan, etc.
Sorry, I’m so busy and have not had time to get a picture of the closed cell insulation. We usually use, but I would try to get closed cell foam insulation at least a half inch thick. You can even tape it to the walls of the refrigerator if you like at the rear and both sides that will definitely do the trick. I’ve never not been able to solve this problem for a customer.
It is a common problem though with this refrigerator.
I think you should be able to solve this problem and your refrigerator was a pretty decent one, but everything comes to an end. Whirlpool still builds a great 30 inch wide bottom freezer refrigerator here in this country. Just sold one today for a customer, just be sure to get the US built one not the Mexican one if you decide to buy a new one.
John L
Well, if I can test your patience again, my struggle continues!Hi Wendy, thanks for posting all the great photos.
John L
So a sheet of 3/4" closed cell insulation is on its way; I should be receiving it in a few days. I'm not optimistic, since nothing was gained from rope caulk on three sides. I can't understand why if too much cold air is escaping, and you say it's common, just why that happens. And why it suddenly started to happen after I went inside to clear a clogged drain. Can't help thinking I did something wrong, but I can't guess what.Hi Wendy, thanks for posting all the great photos.
John L
Thanks a lot for this good explanation. Since caulking hasn't helped, it does make sense that too much zero-degree air hitting the roof of the freezer is really the problem, as you say. Yet while I accept that the foam cover could lose insulating quality with time--gradually--there was no problem before I removed and replaced it, and then boom!Hi Wendy, I don’t think the problem is necessarily air leaks as much as the fact that the crisper drawers are installed above the evaporator compartment on this refrigerator, when you consider the air temperature in the evaporator compartment can be 20 below zero I think it’s more of proximity thing most bottom freezer refrigerators were not built this way and you’re finding out why I think.
If you could still get that foam cover for the evaporator that would probably go a long way to solving this problem. I think the foam loses some of its insulating ability over time.
Subzero had a big problem with this on their built-in bottom freezer models for years their solution was to install a metal panel under the crisper drawers that had an electric heater on the bottom of it and wire it in, in the case of the subzero, there was no air leaks whatsoever because both compartments on the subzero are completely separate. There’s no air interchanging between the two compartments, but again, I think it was just the proximity of being directly above the freezer that caused the problem in the subzero.
John L
