S saz1 Member Joined Aug 8, 2017 Messages 23 Location LA Aug 31, 2017 #2 Took the washer apart to change the spider arm. Wondering if its OK to re-use the tub seal. New one is overpriced, wouldnt mind not getting one if i can get away with keeping the old one.
combo52 Well-known member Platinum Member Joined Apr 4, 2008 Messages 17,015 Location 50 Year Repair Tech Beltsville,Md Aug 31, 2017 #3 Reusing a FL Washer Tub Seal If it looks good you can generally reuse them. I would make sure everything is clean and dry and use a good silicone sealant to make sure it seals and stays that way.
