Our beloved Montgomery Ward topload impeller dishwasher pooped the bed last week (the GSD1250 is now in its place, so that's okay). Tonight, our equally beloved Wards top-loader finished the cycle at 10:00 PM with a full load of clothes and hot water in it. Mysteriously, the timer had advanced to the end of the cycle, but it was apparent that the clothes had not.
A bad week for Electric Avenue, to be sure.
Doinking around didn't yield anything; the timer motor ran, but that was it. I thought that if the motor had died, surely if in the agitate portion of the cycle, it'd fill if you held the infinite water level control to "Reset" like it will do normally.
Nope.
Okayyyy. I called in a lifeline to help brainstorm this one. While on the phone, the machine grudgingly agitated-kinda, but would spin, so I took advantage of the opportunity to eject the water.
What could it be--bad capacitor? Motor? Timer contacts? Lid switch? Luck?
After unloading the clothes, I discovered--oop! Couldn't unload the clothes. One of the percale sheets had lodged itself under the agitator between the skirt and bearing, and jammed the transmission so solidly that the motor couldn't do much more with it.
A quick dismount of the agitator and extraction of the now lovely and crepe-paper-textured sheet resolved the issue, and all's well again with the world.
I can honestly say this is the first time I've ever had this happen to me. Kudos to WCI for their thermal motor cutoff; it works.
Has this ever happened to any of you? After seemingly endless minutes of wire-poking and vicarious consultation of doctrine, I felt like a yutz.
Nope.
