Small Repairs that Saved Big!
daveamkrayoguy
Dec 8, 2010
5,213
Oak Park, MI
<span style="font-size: 14pt;">The Problem:</span>
My blender had my Fall Nightcap of Ice Cream, Caramel Syrup, Angry Orchard's Cinnful Apple Hard Cider, Pumpkin Licquer and a raw egg...
The base made a noise, but the blade inside the glass did not turn...  I could not move the mixture to my other blender glass which was still dirty and inside the dishwasher, so resigned myself to drinking it unmixed, after briefly stirring w/ a big spoon...
But with the glass off of the base, the motor did turn--and I even tried to see if I could set the glass on it while it was turning--finding myself unsuccessful!
Looked for a new blender from the store that I work at, to Bed, Bath & Beyond, promising myself a shopping-visit to Ace Hardware and our last local K Mart, as well as Target, and Kohls--where I believe I bought my blender at...
<span style="font-size: 14pt;">The Solution:</span>
The glass in the dishwasher after being joined by the glass I was using, got cleaned, after there was, a day later--hours later, actually--a full load of dishes...
So with the other glass on its base w/ its blade, the blender worked--and actually making me another milkshake--this time a Chocolate Shake for me & my daughter...
I bought a kit of parts for my blender to replace a cap that got chewed in the blender (Cap, Blade, Base, Lid, Cap & Gasket from Amazon) & later bought a jar w/ a lid, blade & a cap as well as a gasket & base, at a Salvation Store... So with three blade-shafts, actually found myself with a still-two... Two that spun, empty & full; one, which even empty that did not-just had the 'Grrrrr!' of the blender's motor...
Don't know which one I discarded--one of the replacements, or perhaps the original...  But I tested all three to find there was one I needed to have weeded out...
<span style="font-size: 14pt;">What Might Have Caused the Part's Failure and What Might Contribute to Longevity and a Future Long-Lasting Life-Span:</span>
I tend to lift the glass off the base after shutting off the motor, so perhaps the shaft on there grinds the one underneath the blade...
I have pictures to show a shaft w/ a tooth or two bent or missing from the small gear, and one of the two still-working ones I had volunteer:
(The blade shaft not in a blender jar's base is the worn one; the good blade shaft is shown in the base of a blender jar...)
<span style="font-size: 14pt;">A Moral:</span>
Don't take the blender jar off the base during even the motor winding down--fun as it to me may have been...  It, as I suspected I'd found might promote wear 'n' tear...  But the important thing, and this I was anxiously getting to:
(Another paragraph) The blenders I saw in both the Wal Mart that I work at, as well as the Bed, Bath & Beyond were no where near as good as my old, red Oster!  No, no!--They range from cheaper Hamilton Beach's & Black & Deckers, to Osters that get pricey, offering no more than a glass jar--and a round one, as opposed to the long-familiar Oster square which mine has, so yet I can't even transfer it to the new unit (well, maybe I can--the base is still round, but I doubted every bit of it), and then going to the expensive (and notoriously not-as-good-as-advertised & promoted via. demonstration programs, as paying three-digit-steep pricing) Ninjas...  While Bed, Bath & Beyond had yet even more expensive propositions, ranging from more than $300 to almost $600 for something you'd sooner see at your local Baskin Robbin w/ a still-plastic jar...
<span style="font-size: 14pt;">Your Insights & Experiences:</span>
What have you encountered, that was similar, in any appliance breakdown or something that called for your own trouble-shooting, that at minimal or no-cost saved you BIG $$$ on an other-wise expensive repair or repair-S????
(And the unmixed mixture wasn't too bad--even drinking the raw egg that solidified itself...  Rocky Balboa barfed--not me! LOL!)
-- Dave
[this post was last edited: 10/4/2015-22:52]
Two stories.
The starter motor on my 98 Dodge Ram three quarter ton diesel failed and the dealership wanted several hundred dollars for a new one. I took the darn thing out and found the problem was nothing more than failed contacts. New ones cost fifty cents and took about an hour to install.
More recently my Frigidaire Gallery stacked washer/dryer failed to pump the water out of the tub at the end of the wash cycle. I found no voltage at the pump to run it, so I traced the wires back to the timer and a set of burned contacts. After pulling a strip of fine sandpaper through the contacts a few times to clean them up it worked fine and has for several years now.
(knock on wood)
WP DD Washer Repair
When the agitator dogs went out on our 12 year (at the time) Whirlpool DD set I called around to different appliance places and was quoted anywhere from $350.00 to "just throw the machine out and buy a new one. It's too expensive to fix". Then I found aw.org. I found out that I could fix it myself. For a grand total of $25.00 including shipping for an agitator overhaul kit and 20 minutes of my time.
Some kind of fuel sensor went out on my BMW X5. The check engine light came on and the engine idled very rough. The dealer wanted $275.00 for diagnostics and up to $300 for a part. I looked the problem up on the internet and found that the sensor was located right on top of the engine in plain sight. I ordered a new sensor from rockauto.com for $48.00 and replaced it myself in 15 minutes. No more check engine light and the engine runs like new again.
Dishlex (Electrolux) Dishwasher
Decided that it no longer wished to heat water at all....
Mayner and Cochran wanted $150 to come and diagnose (including the call out fee and first 15 minutes) and then an additional $66 per hour plus parts...which was going to set me back about $350 in total.
So I asked my friend GOOGLE about heating issues on the model number only to find that there is a fairly common fault in the circuit board - on one of the electronic parts, the solder cracks and prevents the heater from engaging. I even found step by step instructions.
A small investment of $7 for a soldering iron (solder included) from a cheapie shop and an hours time to find my way around the electronics and she was fixed. I've subsequently fixed two more of the same model.
All up saving across ours and our friends - $1050.00.....less $7.00 for a soldering iron.
Result!
Result!
Hi ronhic
interesting. I recently did the exact same repair on my sister's Electrolux dishwasher.
Soldering iron cost $13 from Jaycar. (I have soldering irons at home but not at her place.)
I made the mistake of trying their new lead-free solder. AWFUL stuff. Back to normal stuff next time.
IT WAS A COUPLE DAYS AGO:
This tool saved TENS on repair & maybe HUNDREDS on a new Garbage Disposal, plus installation:
Made a lot of trips to and from the fuse (breaker) box, after pressing the reset button under the disposer unit after a faint Hummmm was heard when I turned it on, or otherwise heard NOTHING... (See? Check the breaker/fuse!)
Then, an Online trouble-shooting diagram pointed out a hole underneath for inserting a special wrench, which I realized I had, hence after inserting it & turning it, I switched it on & after-since it has relentlessly done its Job!!!!
-- Dave
NOT SO WITH MY VACUUM:
Ages & ages of dirt in the carpet rendered my Kenmore vacuum cleaner working, over-working, working hard and over-working hard, and even changing the already-full bag, found her just blowing dirt around...  (The den and daughter's room are the only rooms fully-carpeted, the other rooms have area rugs, or just hard floors...)
I took the vacuum to the repair shop, where I've gotten a couple street components, one my radio/amplifier, the other a CD, which broke again & had just resigned myself to replacing though with nothing nowhere as good...
However, the hose seemed to be still blocked, and actually right at the power head where the dirt comes in, and where there was a black plastic rectangle, which to even the repair man got dismissed as a component, it was actually a BLACK LEGO, that I removed, (after $25 for unblocking dirt from somewhere, (else) anyway) then she's been running like a champ ever since!
In the background behind her, a Dirt Devil carpet shampooer that I bought to finally destain the years & years of stuff spilling on the carpet in that den...
I also bought a Bissell hard-floor stick as well, despite the setting on the vacuum that can clean her floors, too; it's just maneuverable and lighter...
-- Dave
DR error on the Frigidaire front loader
It also didn't spin and was emitting a series of beeps in sync with the flashing error code instead of the usual 3-beeps repeated 3 times end-of-cycle chime. 10 minutes on Google, a quick sweep of Amazon and I had a new door latch in a couple days. In the interim, washed a single load at the laundromat and brought it home to dry.
A screwdriver, a minimal amount of elbow grease and it was soon washing the towel rags I had used to sop up the water.
Part: $40ish. Labor: $0.00. Savings: probably 2 or 3 Ben Franklins.
