Speaking of hidden bake units... COOLERATOR!
What a treasure!
Stainless steel was certainly more able to withstand the heat than the porcelain, although that could have been an aluminum panel, too. Note that it was removable for easy cleaning also.
I have a December, 1951 magazine ad for this range and due to International Telephone & Telelgraph's wonders, the clock could control the master oven, the companion oven, the appliance outlet, the giant 2100 watt front unit or the deepwell to make them all automatic, one at a time, of course. It also featured 7 heat pushbutton controls
Such an awesome stove.  If I were looking for a 1950-ish electric range, my search could easily come to an end here.  That thing is is beautiful shape!
For the archives:
Greg, I think they made the range themselves, just like the refrigerators and the freezers. The Coolerator range user's manual I have dates from before ITT bought them.
Why the hell is that expaning trivet on the range? Do they think it goes with it?
Beautiful stove. Almost an original idea don't outsource a product and slap your badge on it. Manufacturing one created jobs back in the day.
As I've stated before, I'm not an electric range person but, this beauty could possibly get me to change my mind.  Just gorgeous!
Something about the styling of the control panel reminds me of an early 50s Buick. Maybe it was the placement of the knobs for the radio or something that corresponds to the big dials near the center of the backsplash.
The placement of the oven door handles is different also, with so many manufacturers striving for placement that was more centered, either on the door or more to the center of the range.
I believe that 7 heat switches are in many ways superior to infinite switches EXCEPT that it takes some experience to determine which part of the coil is heated on each setting. For example, if you were frying in a 12" diameter skillet, it would make more sense to have a setting where just the outer ring of the element is heated so that the temperature would spread to the outer edge of the skillet as well as to the center. On the other hand, if you were wanting to keep a large pot of water at a rolling boil for pasta, you would want the inner coil heated to give greater upward movement in the center of the pan, rather than along its edge to discourage water jumping out of the pan. The two medium high and the two positions between medium and low could be very useful for these purposes and give more options than 5 heat switches. Granted, infinite switches can provide even heating patterns at all settings, but there are times when more is needed. The GRIDDLE setting on a 30" GE range with Sensitemp is a case in point. To provide even eating on the rectangular griddle, it only heated the outer couple of turns of the element so that temperatures would be equal at the edge and the center. I used to use the SensiTemp's griddle setting when using my 12" Farberware skillet for very even temperature across the whole of the pan.
At any rate, it was a range built to last while offering every feature available at the time including a much better and slightly more expensive approach to the hidden bake element fad.
Jamie,
Could it have been a division of McGraw-Edison?  They owned Speed Queen at that time.  Speed Queen is located in Ripon, WI.
Coolerator
polkanut has it right. McGraw Edison owned both of those companies. As I remember, air conditioners were a huge catagory for them, Funny name for a range though.
Well Taken Care of....
...for it's years.  A beautiful stove that would likely last a long time.
So the deep-well feature was interchangeable with a burner - or how did that work?
@jamiel - I haven't heard the name Central Hardware in at least 35 years.  Brings back memories.  Wonder what happened to them?
John, many ranges, once they went to sealed rod elements for the deepwell cooker, had an element that would sit at the bottom of the well, but could also be raised up and locked in place to serve as a fourth surface unit.
Deep wells were originally put on ranges to make electric cooking more economical, especially for larger quantities of food that had to cook for a longer time since the well originally offered some insulation around the pan and some of the lids for the pans had insulation in them also. They began to look old fashioned (the style, not the drink) and were phased out. Frigidaire was probably the last manufacturer to offer them up to 1959 or 60. I guess when people had the opportunity to choose between a deep well and a 4th surface unit, they picked the 4th surface unit enough that the deep wells were no longer favored. I would imagine that for short women, it was maybe hard to see down inside of the pan in the back corner of the cooktop. With GE and Hotpoint ranges, the deep well unit was another 6 inch unit, but with Frigidiare and Westinghouse ranges the lift up deep well unit was another 8 inch unit. GE was one of the first brands to eliminate the deep well.
drifting a bit to Central Hardware...
CH was a victim of the big box home centers. A shame, really, because they were sort of your local Ace hardware on steroids--everything from scoop to nuts was their jingle, if I recall correctly. Service was excellent.
Their big store on Page Boulevard is now a furniture store, I believe.
Yeah, Central Hardware was the greatest. They closed down in roughly 1990 (although they did fend off Home Depot for a long time...believe that St. Louis and Indianapolis were some of HD's last cities to enter). They competed with HQ. They had a really interesting product mix including auto service/tires, major appliances and audio/video, lumber, lawn and garden, plumbing, housewares, bulk fasteners, etc. They were unionized (interestingly)... Lots of nice memories from them. Among other things...the "back door" in the Kirkwood/Big Bend store; the piles of the Post-Dispatch every Saturday afternoon; pushing all the buttons on the avocado appliances; climbing on the riding lawn mowers, the big manila "PLEASE PAY CASHIER" envelopes that they put keys which they cut into so you couldn't shoplift them.
PS...found the below. Interco was a local holding company that had multiple retail formats in the midwest
http://www.stltoday.com/business/lo...cle_84ef0dac-9fcc-11e1-ab98-0019bb30f31a.html
Makes Sense....
Tom, thanks for the explanation regarding the deep well feature as I had not a clue.  The height challenge issue - then the 3 vs. 4 burners - all really makes sense - explains the transition away from the feature.
Jamiel - thanks for the link re Central Hardware former President -  interesting.   Coolerator appliances being made by McGraw-Edison, (at that time) and sold at CH makes further sense now because I remember my dad purchasing our first AC unit which was a McGraw-Edison central air unit from Central Hardware.  I think McGraw Edison's window units were sold as Coolerator - but not completely sure.  I wonder how many other brands were made by McGraw Edison?
Hope someone gets that Coolerator stove featured in this thread - they'll sure be getting a piece of American history when quality was part of the design goal.
John
