spec-tak new detergent
Looked up their website-that company caters to commercial and large users-and specializes in sports and work uniform cleaners.Their website is quite good.They also make and sell detergent dispensing-mixing equipment for commercial-industrial washers.They make and sell surface cleaning agents,too-for janitorial use.One of those secrets right under my nose until now.They have been in business since 1958!-so the website says.
Camon! With that washer how can you possibly obtain it clean?
Red clay is a stupid dirt kind, I get it out with a simple hot wash and soap....not even any oxy bleach or enzymes, the plain soap would do it, , how many times I got covered in it while playing tennis and my sneakers also, they always got out perfectly clean....
Those pants also look synthetic blend pants, even easier to get clean......give them to me lady!
Ahahahaah.....
When I was younger...
I used to play softball. Tide Powder (phosphate free) the old huge scoop formula, and warm water, was enough to get them back to bright clean.
She used a Liquid Detergent, in that video, which, doesn't contain oxygen bleach, so all it had was Enzymes working on the stain. You need a bleaching agent to get rid of Mud & Clay.
Honestly though, in America, Clorox (liquid chlorine bleach) dominates the Stain Removal Market. I'm surprised moms would complain about Laundry, when they have a cheap & very effective method of Cleaning uniforms, in there laundry room.
For what it's worth though...
This "Miracle" detergent, does contain, Sodium Tripolyphosphate. That alone, should have a decent effect on the red clay.
LCB, although somewhat caustic, has been used safely, as long as directions are followed, for years, there can be some damage, over time.....some people treat it like its drain cleaning lye acid, and will damage the fabric just by being in the same room...your mileage may vary...
whats at hand here is a number of 'two rights don't make a wrong situation!'
I have worked in a professional laundry in the past, first, industrial chemicals should never be used in a residential machine...I have seen the damage it can do to a machine....the stated product was designed for industrial uses in industrial machines....now, they may alter part of the formula for home use, but guarantee its not the same, so the results may not be the same...
the next thing is they mention using HOT water, again, we had water hotter at the laundry than what would be at home, and the best part, she is using a Cabrio, for which we all know, no matter how HOT your water heater is set to, the HOT selection gives you LUKE WARM at best....how much you want to bet she never opened that lid to ever check that the temp was never HOT enough....
her first mistake according to the company was that she washed in WARM water, thats what she selected on the control panel.....in reality, it was COOL.....
willing to bet, if that uniform was cleaned by the company, in industrial machines, and using their industrial strength cleaner, no stain would be left behind!....
sometimes, you can't always get the same clean at home that they would......all she had was the dubbed down chemical.....she didn't have all the rest of the equipment...
after all, for those who watch football, baseball, soccer....those guys mud wrestle all the time.....but at the beginning of every game, those uniforms gleam!.....there has to be something behind it!....outside of the towel boy!
Instutional Laundry
Uses Lots & Lots of Chlorine Bleach. Although, they normally followup use with it, with an "anti-chlor" solution, to knock out any residual lingering chlorine left in fabrics.
Chlorine Bleach, is Generally a safe & most effective method for removing stains out of white & colourfast Cotton. If the proper conditions are there, and the directions are followed, you can get really good results from it.
